Hidden Fairing Bracket Options - Road Glide Forums
 3Likes
post #1 of 15 (permalink) Old 01-09-2019, 04:33 AM Thread Starter
RunningWild17's Avatar
Good Morning,
Recently purchased my first HD RGS and loving it. Already dreaming of the customization possibilities. I really want to install new crash bars on it but the fairing brackets need to be removed. There are a lot of options and with different designs to choose from. The two that stand out are the Hell's Foundry Invisible fairing support kit and the PauleYaffe's Stealth fairing support bar. Is anyone familiar with both of these products and explain which design is better? Thanks for any feed back.
File Type: jpg product-stealth-fairing-support-bar-2015.jpg (48.8 KB, 31 views)
RunningWild17 is offline
post #2 of 15 (permalink) Old 01-09-2019, 06:38 AM
Cokebeard's Avatar
i have the Hell's foundry "invisible" on my "09 RG. i like it. makes the fairing stiffer, in my opinion, as it's now connected right to the frame. i'm sure both of those would be fine, it just comes down to aesthetics and if you want to take the front end off for a cleaner look with the yaffe. i'm currently having mine painted over the winter as i have my inner fairing color matched. that's as far as i'm gonna go for aesthetics.
'09 Mirage Orange Pearl Road Glide & '06 Midnight Blue Metallic Street Glide
Cokebeard is online now
post #3 of 15 (permalink) Old 01-09-2019, 07:55 AM
direwolf's Avatar
I just did the Hells Foundry hidden faring brackets on my 09 FLTRSE3 so I could add lowers. It dies seem to make the faring quite a bit more solid &the look is much cleaner.
...2009 SERG...Last of the Hand Built's..
direwolf is online now
post #4 of 15 (permalink) Old 01-09-2019, 08:46 AM
Nordic Berserker's Avatar
They all do their job and don't think you can go wrong with either of em. I have Dirty Bird's bracket on my 2012, works great 👍🏻
https://dirtybirdconcepts.com/produc...iring-bracket/
Nordic Berserker is offline
post #5 of 15 (permalink) Old 01-09-2019, 10:02 AM
BH#103's Avatar
What year is your bike?
"SLIVER"
BH#103 is offline
post #6 of 15 (permalink) Old 01-09-2019, 10:39 AM
direwolf's Avatar
Wish I would have known about this one before I went with Hells Foundry, not that Iím unhappy with Hellís Foundryís product. Just could have saved a few $$$ for some other mods.
post #7 of 15 (permalink) Old 01-09-2019, 11:40 AM
Willy_B's Avatar
I had the hells foundry on my 2012 and then switched to the dirty bird when i raked the bike. Running hellís foundry on my 2017 also. The dirty bird was nice but you have to remove your inner fairing to put it on. It is A LOT of extra work to install it.
direwolf likes this.
Willy_B is offline
post #8 of 15 (permalink) Old 01-09-2019, 12:53 PM
Dire wolf, All you did was install the hidden support and were able to add lowers? You didn't have to change the main fairing bracket to the 2010 part? Everything I have read says the main bracket has to be changed.
If this is the case, its game changer for me
phillyfan1 is offline
post #9 of 15 (permalink) Old 01-09-2019, 02:33 PM
direwolf's Avatar
I installed Hells Foundry adjustable faring mount so I could raise the faring 2Ē for the lowers
Also went with their internal faring support so I could forget about the 2010 faring part.
Might have been a bit cheaper going with the 2010 parts but everything I read said you had to trim the lowers where they met with the 2010 bracket. I had bought HD Lowers from a forum member & then had them painted vivid black so didnít want to take a chance on scratching the lowers by trimming.
post #10 of 15 (permalink) Old 01-09-2019, 05:29 PM
Thanks for the info
DAM! I have so much stuff in my fairing, dreading going in there again
03 lowwer fairing still rubs after 2010 main bracket Icecold Paint & Bodywork Section 0 03-30-2015 05:47 AM
hells foundry fairing bracket gtesch Wanted! (Buy or Trade) 3 05-25-2014 11:10 PM
Can anyone make a sketch of the INVISIBLE Fairing bracket? georgec Do-IT-Yourself 34 05-27-2012 11:53 AM
Road Glide Center Fairing Bracket Qman Classifieds Archive (3 months old+) 5 11-01-2011 12:38 AM
Radio bracket rubbing holes in outer fairing 96349 Troubleshooting for Road Glides 13 03-24-2010 11:11 AM
