Oil Cooler Clearance - Road Glide Forums
post #1 of 5 (permalink) Old 01-21-2019, 08:30 AM Thread Starter
Hi. I’d like to run an undermount oil cooler (probably a Jagg) on my 2009 Road Glide which has been lowered 1”.
Will I have ground clearance issues? Don’t want to do a side mount.
Cowtowner is offline
post #2 of 5 (permalink) Old 01-21-2019, 11:01 AM
lil chief's Avatar
Can you clarify on what you mean by undermount vs side mount? If you're referring to mounting it behind the front wheel between the frame downtubes, at the lower part of the front of the engine, you'll have plenty of ground clearance. My 2015 is lowered and the factory cooller presents no clearance issues. If you're thinking under the bike somewhere, I think you'll be asking for issues. Not only ground clearance, but road debris. Sure, they're all susceptible to road debris, but when mounted in the factory location, it's somewhat shielded by the fender and wheel, but still able to get cooler airflow to it.
Lil Chief
lil chief is offline
post #3 of 5 (permalink) Old 01-21-2019, 12:12 PM Thread Starter
Thanks. Sorry to be unclear, I meant the kind that mounts just below the regulator. Jagg calls it a Low Mount - I think it’s similar to the factory location.
post #4 of 5 (permalink) Old 01-21-2019, 12:26 PM
lil chief's Avatar
Originally Posted by Cowtowner View Post
Thanks. Sorry to be unclear, I meant the kind that mounts just below the regulator. Jagg calls it a Low Mount - I think itís similar to the factory location.
You'll be good with that setup. As a matter of fact, my old bike, a 2002 FLHT, was lowered 2", and I put an oil cooler on it, in that exact spot. Never had an issue. The only issue I've had, is that I live on gravel, and one day before coming home it rained. The cooling fins got some muck in them, but it hosed off easily.
Lil Chief
post #5 of 5 (permalink) Old 01-21-2019, 02:52 PM Thread Starter
Thanks for the info, that’s all very helpful.
Oil Cooler Damage rider17 Engine Related 0 12-28-2017 10:46 AM
Oil cooler review Citykid Engine Related 14 04-12-2015 11:13 AM
Oil Bud Oil Cooler install 2013 RG ultra Big_Mo Aftermarket Accessories 0 08-09-2014 09:32 AM
Jagg Oil Cooler turned to Oil Drooler! OldNerdGuy *General Road Glide Discussions/Pictures 6 07-22-2013 11:04 AM
ultra oil cooler 4 sale roadgliderick Classifieds Archive (3 months old+) 3 08-25-2011 02:12 PM
