Lower Front End? - Road Glide Forums
 4Likes
  • 1 Post By gslobo
  • 3 Post By BH#103
post #1 of 5 (permalink) Old 02-06-2019, 09:57 AM Thread Starter
Lower Front End?
I have a 2004 Road glide and trying to lower the front (short legs) I purchased a progressive suspension drop in fork lowering kit, according to the instructions I only need one because I have a damper rod on the right side, has anyone done this? I could use some help? thank you
DarkGlide2 likes this.
gslobo is offline
post #2 of 5 (permalink) Old 02-07-2019, 03:36 PM
BH#103's Avatar
I have not done one, but I would call progressive customer service to be sure you got the right kit before you do anything.
seetiggergo, rlaf75 and ALMOONEY like this.
"SLIVER"
BH#103 is online now
post #3 of 5 (permalink) Old 02-11-2019, 04:45 PM Thread Starter
Thank you, yes I did that...I am good to go now..
gslobo is offline
post #4 of 5 (permalink) Old 04-23-2019, 10:04 PM
Gslobo
Hello DarkGlide2 newb to the forum and road glide fam.
Iím in the same boat you were in. Is it true you just use one spring and compensator?
Thanks
DarkGlide2 is offline
post #5 of 5 (permalink) Old 04-24-2019, 04:37 PM
Taz_FL's Avatar
Back in 2001 I lowered the bike I had at that time. Everything I read on the subject said you should never lower ONLY the front. It was okay to lower only the rear and leave the front stock height but not okay to go the other way. Just throwing it out there, you might want to look into that if you're thinking of lowering only the front.
Taz_FL is offline
HD Front Wheel Bearing Failure FLTR2008Trike *General Road Glide Discussions/Pictures 51 09-30-2014 06:58 PM
HD Profile Low Touring Front 1" Lowering kit didn't lower 1"! jdbaker Suspensions 3 07-13-2012 03:51 AM
The new Rubber Paved Road Ė Traxxion Dynamics AK-20ís tyhlme Suspensions 9 11-27-2011 11:14 AM
Best way to lower front 1" fosterp Suspensions 6 11-14-2011 04:31 AM
Vented Lower Fairing: 2010 Spec Front Fairing Braces. CCRydah Aftermarket Accessories 10 07-25-2010 10:27 AM
