Drive belt options - Road Glide Forums
 16Likes
post #1 of 15 (permalink) Old 02-06-2019, 11:48 AM Thread Starter
Drive belt options
I'm gonna be doing a motor swap in a few week and I'm looking to replace the drive belt since I'll have everything apart already. I'm NOT looking to convert to a chain but I'm wondering if theres anything better/stronger available other than a stock replacement belt. I've seen belts advertised as kevlar or carbon fiber or whatever but are they worth the money?
post #2 of 15 (permalink) Old 02-06-2019, 01:50 PM
RGKen's Avatar
If you are sticking with belt drive I don't think there is any reason to look past the HD belt. I had 93k on my 2012 when I sold it and the last 47k I was running a 120ST with 132tq and I rode it like I stole it with the original belt. Always inspected it and never any issues. It is an extremely durable belt and the only ones I've ever heard of needing to be replaced either had well over 100k miles on it, was on a bike with 145Hp/145Tq and the rider did a lot of hole shots, or if it picked up a rock and it damaged the belt. Outside of that the best option if you are building high Hp/Tq and plan on abusing I would just switch to chain and not worry about it.
ironmark, rlaf75, glide69 and 1 others like this.
2018 FLTRXS
RGKen is offline
post #3 of 15 (permalink) Old 02-06-2019, 05:07 PM Thread Starter
Yeah I should have between 120 to 130tq when I'm done and I do ride it hard now in stock form. I figured since it'll be apart already I'd change the belt to be on the safe side since it has 60k on it and I should be close to doubling the power numbers. I guess the stock belts do hold up pretty good.
post #4 of 15 (permalink) Old 02-06-2019, 07:41 PM
I put a new belt on my bike when I did the engine swap and I stayed with the HD belt and when I took the old belt off it looked like new except for a little lighter color. I would recommend since you have it apart to put a new stator in the bike and new primary case bearings.
rlaf75, RGKen and BigWillieDP like this.
post #5 of 15 (permalink) Old 02-07-2019, 12:38 PM
Road dawg's Avatar
Good advice from IM, and yes I would stick with the stock belt also, extremely durable.
Road dawg is offline
post #6 of 15 (permalink) Old 02-07-2019, 03:33 PM
BH#103's Avatar
Original belt or original replacement will serve you well, shouldn't have an issue.
rlaf75 and Smarty like this.
"SLIVER"
BH#103 is offline
post #7 of 15 (permalink) Old 02-08-2019, 04:49 AM
ER.RN's Avatar
I’m just curious, what would be the advantage to converting to a chain? Wouldn’t that just increase maintenance or is there some performance advantage?
ER.RN is offline
post #8 of 15 (permalink) Old 02-08-2019, 05:39 AM
RGKen's Avatar
Yes, the chain gives you more durability and it will also give you a little more instant Tq. There is more maintenance with the chain but for the guys that are going with higher performance engines, and are going to use the power, going chain drive is the best option.
2018 FLTRXS
RGKen is offline
post #9 of 15 (permalink) Old 02-08-2019, 07:21 AM
smitty901's Avatar
Common to hate on anything HD , but the belts are great. Only time you really see one fail is user issues. One on my 1996 is 22 years old still going. Have never had to replace one on any HD ever.
RGKen likes this.
smitty901 is offline
post #10 of 15 (permalink) Old 02-08-2019, 10:50 AM Thread Starter
There is no "hate" on anything HD. I'm simply trying to find out if there is something that might be better or stronger for the motor upgrade I'm doing. I'm trying to get as much info as possible because I'm looking to do it right the first time. The bikes gonna be apart so I'm gonna replace "wear" items as it goes back together
RGKen and flhman like this.
Drive belt replacement Slider1156 Engine Related 7 11-16-2016 09:41 AM
Drive belt tension Chuck1073 *General Road Glide Discussions/Pictures 9 10-18-2016 09:03 PM
Knight prowler silent belt drive cam Straitline Engine Related 6 07-29-2015 12:57 PM
Every fourth tooth half missing on final drive belt ccallahan Tech Area 3 07-09-2015 09:19 AM
Drive belt question Boogitybob *General Road Glide Discussions/Pictures 5 05-09-2012 11:46 PM
