2018 Road Glide Big Front Wheel - Road Glide Forums
 12Likes
post #1 of 19 (permalink) Old 05-10-2019, 02:12 PM Thread Starter
Can someone tell me what the largest size wheel I can put on a 2018 Road Glide Special without re-doing the whole front end?
post #2 of 19 (permalink) Old 05-10-2019, 02:22 PM
duglauraflht's Avatar
Like to welcome you with your first post...Hearty welcome!
21s would set off th at front end nicely instead of stock OEM...meh.
Those 21s and BARS would look killer...
Big fan of BARS!!!
Buddy just did up his 21s with blacked out forks!
08Zinc, Jacksprat56 and Bevis like this.
duglauraflht is online now
post #3 of 19 (permalink) Old 05-10-2019, 03:26 PM
Rays Road Glide's Avatar
Welcome, 21” wheel is as big as you would want to go, after that you’d have to get a Neck Kit.
duglauraflht likes this.
RMC, 2017 Vivid Black RGS
Rays Road Glide is offline
post #4 of 19 (permalink) Old 05-12-2019, 12:36 AM
I’ve got a 23 with no rake. It’s totally fine to me.
Dzebold is offline
post #5 of 19 (permalink) Old 05-13-2019, 05:29 AM
Like to see pixs???? Sir Swomacattack would also like pixs!!! just saying?
Jacksprat56 likes this.
post #6 of 19 (permalink) Old 05-14-2019, 10:52 AM
Shark of the Month October 13
Location: Was northern Maine, now gulf coast of Florida
Opinions vary, but I think it's generally accepted by pro builders that a 21" is a straight swap, a 23" can be a straight swap but handling will benefit greatly from at least installing a raked triple tree, lots of guys use the one from a trike which is believe is 7 degree. Some say that you should also rake the head before installing a 23". Anything larger (26/30/32) definitely need raked neck and raked trees. Here's Paul Yaffee from Bagger Nation on the subject:
Paul Yaffe's Bagger Nation | RAKE YOUR BAGGER
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming “Wow! What a Ride!” - HST
Uncle Fuzzy is offline
post #7 of 19 (permalink) Old 05-15-2019, 09:31 AM
PS: If you put a 21" on and plan to use the original fender, you'll want to elongate the fender mounting holes just a wee bit so that you can move the fender back a hair which will eliminate any chance of the tire rubbing the fender. If you are thinking of changing the fender over to something more streamlined, check out Klockwerks. They offer quite a few style options, the correct mounting blocks, and a finely finished fender that you're painter will hardly have to touch before spraying. Have fun with this mod, it'll change the look of your bike for the better.
post #8 of 19 (permalink) Old 05-16-2019, 09:50 AM
RGS_2019's Avatar
Do you just elongate the rear holes and move it forward a bit or all four and move it up a bit? Plan on going 21 in the near future.
2019 Billard Blue RGS - Legend revo a rear shocks, SE torque cam, SE air intake, SE tuner, V&H Titan oversized slipons, factory 47 12" bars, memphis 8.5" screen and more to come!
RGS_2019 is offline
post #9 of 19 (permalink) Old 05-16-2019, 10:04 AM
Willy_B's Avatar
On the 15+ road glides you can’t just elongate the holes. You either needs brackets to lift entire fender up 1” or a new fender designed for a 21” wheel.
Willy_B is offline
post #10 of 19 (permalink) Old 05-16-2019, 11:41 AM
RGS_2019's Avatar
Appreciate it! Going to buy the brackets and get ready for that 21" wheel
RGS_2019 is offline
2018 Road Glide Dejaceno1 *General Road Glide Discussions/Pictures 2 01-17-2019 04:40 PM
2018 harley road glide 'flashing' education Luckys2018RoadGlideCustom Aftermarket Accessories 6 01-05-2019 07:29 PM
SCOOP: 2015 Harley-Davidson Road Glide Spied VS Jeff Home Page News 9 09-10-2015 11:54 AM
Road glide seat and fender and agitator wheel. Orange09Glide Parts for Sale 10 09-20-2014 12:50 PM
2009 Road Glide front wheel oldtimer63 Classifieds Archive (3 months old+) 8 12-30-2010 09:10 AM
