Ciro Frame Mounted Adjustable Highway Peg - Road Glide Forums
 5Likes
post #1 of 15 (permalink) Old 10-16-2019, 02:26 PM Thread Starter
Bluesguy's Avatar
I had already purchased the 1 1/4 " floorboard extensions and was about to pull the trigger on the Ciro frame mounted highway pegs but was concerned about the extended bolt lengths. Sent Ciro an email (impressed - they called with a response) and said I'd need to buy longer bolts in order to mount their product. Strikes me that's a lot of stress on an extended platform. Is anyone using the Ciro's with floorboard extensions?
Thanks
Bluesguy is offline
post #2 of 15 (permalink) Old 10-16-2019, 02:48 PM
RFG7680's Avatar
I was considering these. But I have the Kuryakyn extensions that mount to the board itself. So I'm thinking it's a non issue for me. But will my extensions be in the way?
If you use grade 8 bolts I think you'll be ok. Unless you stand on your boards how much pressure are you really putting on them?
I may just use the crash bar mounts now.
RFG7680 is online now
post #3 of 15 (permalink) Old 10-16-2019, 03:20 PM
skratch's Avatar
i just went through this with these. i put a set on the wife's bike, she had the 1'' floorboard extensions. i had to remove them. you can't just use longer bolts. there is a spot where you would need another extension/spacer. it's hard to explain, but hang on, i'll get you a pic....
okay, here's a pic. notice the red circled area, with my extensions, it was just a cylindrical spacer that went under the front part of the mount, but nothing where it's circled. you could either add one (it would have to be just a tad different length because you can see how the surface is 'stepped') or remove the extensions. with these floorboards, my wife doesn't notice the lack of the extensions so much.
skratch is online now
post #4 of 15 (permalink) Old 10-16-2019, 05:45 PM
+1
Dvidal is offline
post #5 of 15 (permalink) Old 10-17-2019, 08:24 AM Thread Starter
Bluesguy's Avatar
I appreciate the comments. I've reconsidered the extensions vs. purchasing the Ciro's vs. having crash bar mounted highway pegs...again. Took the plunge last evening and ordered the Ciros. Looking forward to trying them out.
I'll have an unopened 1 1/4" Floorboard extension kit for sale soon.
Ride safe.
RFG7680 likes this.
Bluesguy is offline
post #6 of 15 (permalink) Old 10-17-2019, 09:27 AM
BH#103's Avatar
I put the Ciro's on with Kuryakyn extensions. 3/4" I believe, just used extended bolts and an appropriate spacer for the other and all is good!
RFG7680 likes this.
"SLIVER"
BH#103 is online now
post #7 of 15 (permalink) Old 10-17-2019, 12:25 PM
Clump's Avatar
Ride safe.
The Ciros are great! I added extended brake and shift levers from Soft Brake and I'm really happy with the setup.
2020 Road Glide Special - Billiard Red - 114 CI Stage 2
Clump is offline
post #8 of 15 (permalink) Old 10-17-2019, 12:30 PM
LoneCabbage's Avatar
Same here on both, love the Ciros!
LoneCabbage is offline
post #9 of 15 (permalink) Old 10-17-2019, 01:20 PM
madmat's Avatar
The cyros rock, was thinking of adding extensions. Nice to know I can.
jimAZ likes this.
18 RGS Bonneville Salt Pearl
madmat is offline
post #10 of 15 (permalink) Old 10-17-2019, 05:34 PM
BH#103's Avatar
Ya buddy! Get the extensions that you want and add that size to any bolt you have to remove in order to install the Ciros. Even though only 2 bolts hold the original boards on, there is a third you will have to remove to mount them. Also grab 2 cylindrical spacers the same size as the extensions for that other bolt you have to remove. Done and done, I love them!
madmat and RFG7680 like this.
"SLIVER"
