Shifter Linkage - Road Glide Forums
post #1 of 9 (permalink) Old 09-24-2013, 07:10 PM Thread Starter
chkywuky's Avatar
Shifter Linkage
Have any of you guys mounted the front shifter linkage to the inside of the front linkage arm.I did and I like it.It's a straight shot to the back arm versus angled in when mounting on the outside of the front arm.It tucks in closer to the motor also.
chkywuky is offline
post #2 of 9 (permalink) Old 09-24-2013, 07:31 PM
When I replaced my ends , I thought about doing it that way. Does it shift any smoother , or just appearance ?
post #3 of 9 (permalink) Old 09-24-2013, 07:32 PM
I agree it looks better but on some bikes, the linkage will contact the fins when mounted on the inside.
Captain13 is offline
post #4 of 9 (permalink) Old 09-24-2013, 07:43 PM Thread Starter
chkywuky's Avatar
I had it on the outside first and it would shift ok but it's smoother on the inside because it's more of a straight shot back [no angle] like the stock mounting.You do have to lenghen the shift rod a little so as to move the front arm forward enough to miss the cyl. fins.I did some fiddling with some different hardware and such but now it's golden. better than stock IMO.
chkywuky is offline
post #5 of 9 (permalink) Old 09-24-2013, 07:58 PM
zemo1017's Avatar
Put a Road Glide script linkage from Harley on mine. The ends had heim joints on both ends. The shifting was smoother then. Never considered the swap. I see you have the heim joints on this linkage. It may be they improved the feel more so than relocating.
zemo1017 is offline
post #6 of 9 (permalink) Old 09-27-2013, 05:56 AM
I just put a HD bar & shield logo linkage on my 03 yesterday. I too think it may be the heim joints that makes the shifting smoother. Shifts much smoother than the stock linkage and both front and back are mounted on the outside.
2003 Anniversary Road Glide.
Neil V. is offline
post #7 of 9 (permalink) Old 09-27-2013, 08:52 PM
+1, depends alot on the hardware and throw, always outside on tranny, you know
reds4 is offline
post #8 of 9 (permalink) Old 09-29-2013, 11:25 AM
TLWiz's Avatar
I bought the linkage cover. It looks nice. It rattles sometimes. I still have the stock ball and socket linkage. I wish I had just bought the decent linkage to start with. I am sure I will this fall and then sell the waste of $$ cover which is probably harder to install than the linkage itself.
TLWiz is offline
post #9 of 9 (permalink) Old 09-29-2013, 12:44 PM
Ohiobellboy's Avatar
Sure cleans it up nicely. May have to play with that on mine.
A.K.A OBB
Ohiobellboy is offline
chrome shifter linkage cover led520 Equipment-RG 1 12-05-2012 10:42 PM
Arlen Ness Deep Cut Shifter Linkage (Never Installed) SIG556 Classifieds Archive (3 months old+) 1 08-18-2012 11:07 PM
Shifter linkage, winshield gasket and more... Effenglide *General Road Glide Discussions/Pictures 6 06-28-2011 10:28 PM
One of a kind shifter linkage hotrodad *General Road Glide Discussions/Pictures 15 02-10-2011 12:01 PM
Heim Joint shifter linkage Grillfish Troubleshooting for Road Glides 3 04-19-2010 06:08 PM
