Question about HD Stealth Luggage Rack - Road Glide Forums
post #1 of 13 (permalink) Old 10-10-2013, 03:14 PM Thread Starter
Ernster500's Avatar
For those of you with the HD Stealth Luggage rack, any problems with fitment? I recently acquired a rack from an eBay auction. The rack is in very good condition with no visible issues. It also has the HD markings inside the underside of the rack blades, so I'm pretty sure it's genuine.
The problem I'm having is that it seems just a little tight getting on the rack to the point where I either have to try to pull out the mounting points to fit onto the docking hardware. Seems like I really have to work to get it on.
Is this normal?
Once on, the fit is nice and tight with no rattling or movement.
I didn't have any problem with my backrest fitting on. But the rack just seems slightly off where I can't say "it fits like a glove."
What has been your experience?
E
2012 Big Blue Pearl FLTRX
Ernster500 is offline
post #2 of 13 (permalink) Old 10-10-2013, 04:33 PM
GlideShark's Avatar
I have had it for awhile but recall it was sort of a pain in the ass getting on at first. Would not go into mounting points smoothly like my other attachments. All good now, easy on and off. If it is genuine (I know some knockoffs on eBay), based on my experience, I think you may be fine.
Now, I did have to return one since it was not "matched" to the mounting hardware but there was no way to get that one on. Just a dud they shipped out.
GlideShark is offline
post #3 of 13 (permalink) Old 10-10-2013, 04:40 PM
I am on my third stealth luggage rack and all three have fit differently. What I figured out was the end can get bent in or out which makes it hard to push into the pins on the bracket. I did a bit of careful modification to the bracket. If it need opened or pryed farther apart I did this or if it was a bit too wide I bent it in just enough to line it up. After that they worked great. I have also had the locking part come unscrewed so keep an eye on this as well.
FireBall is offline
post #4 of 13 (permalink) Old 10-10-2013, 04:41 PM
mllgator's Avatar
Could it be a pre 2009 model?
mllgator is offline
post #5 of 13 (permalink) Old 10-11-2013, 12:51 AM Thread Starter
Ernster500's Avatar
Thanks for the replies!
Any advice on how you modded it?
No, I think the pre '09 actually bolts on to the bike.
post #6 of 13 (permalink) Old 10-16-2013, 01:14 PM
jchar27's Avatar
I had the same issue with my stealth rack. In fact, I couldn't get it on at all, so I put it back in the box with the intent of taking it back to dealer. The mounting points were too narrow for the docking station. The backrest fit perfectly. The next day, I decided to put it on the carpet in my house and step on the inside of the bracket on one side while pulling up on the other side very gently. I didn't notice if it actually stretched a bit, but when I put it on the bike, perfect fit. I would say just be careful you don't over stretch which may risk cracking the chrome.
2018 CVO Road Glide, Black Earth/Vivid Black
Fuel Moto Road & Track 2 into 1, Fuel Moto custom K & N Air Cleaner, Redshift 468 cam, Power Vision.
2003 Super Glide 100th Anniversary Edition
jchar27 is offline
post #7 of 13 (permalink) Old 10-16-2013, 03:31 PM Thread Starter
Ernster500's Avatar
That is exactly the problem. I'm able to get it on but it is a very tight fit and takes some prodding. I'll have to try your technique. Sounds like it may be the best way. I haven't taken it off since I got it on, so, it should be a fun job taking it off too!
Thanks for the tip!
post #8 of 13 (permalink) Old 10-16-2013, 03:57 PM
Same issue. After a few times I found that I had to push one side in a hair further to help it seat evenly. Maybe issue is with 4 point docking.
BigWaterJim is offline
post #9 of 13 (permalink) Old 10-16-2013, 04:09 PM Thread Starter
Ernster500's Avatar
I don't think it's the docking hardware only because my backrest does fit like a glove with no issues getting it on and off.
post #10 of 13 (permalink) Old 10-16-2013, 05:03 PM
GlideShark's Avatar
If it's still giving you problems take it to the dealer and tell them to put it on. After a little time of looking like a monkey with a football they will get you a new one. That's what I did with the first one I had that was defective. They did not believe me over the phone.
HD Stealth 2up Luggage rack jchar27 Parts for Sale 1 11-20-2017 04:45 PM
Stealth Tour Pak Luggage Rack Functionality Question REDRUM Aftermarket Accessories 3 03-25-2014 09:17 PM
Stealth luggage rack dwighop Equipment-RG 10 10-25-2012 09:58 PM
