What to do with wires for detached tour pack? - Road Glide Forums
  • 1 Post By RoadGlideRider
post #1 of 10 (permalink) Old 11-17-2013, 11:02 AM Thread Starter
I just installed the quick detach kit for my 2011 RG Ultra. There are three sets of wire bundles that get unclipped and just hang on the rear fender. I may try to tuck them under the seat but it's really tight in there.
What solutions have any of you guys figured out for these wires? Pictures?
Thanks in advance.
Dire Wolf is offline
post #2 of 10 (permalink) Old 11-17-2013, 11:16 AM
kenrena1's Avatar
Thanks in advance.
I cut the harness an installed a connector next to the docking bracket . When I remove the tour pak I just unplug this connector and it tucks in behind the docking bracket. Cant see the connector unless you look close
....................... My girls ......................................
kenrena1 is offline
post #3 of 10 (permalink) Old 11-17-2013, 12:01 PM
I went with the hidden AM/FM and CB antennas in the front fairing, so that eliminated those cables. Cut and added a connector for the TP lights so that harness and the speaker pod connectors unplug, roll up and slide under my rider backrest mount. The passenger headset connection loops around and lays over the ECM. No problems so far. I did add speakers in the lowers so I'd still have plenty of sound with the TP off.
DuraGlide is offline
post #4 of 10 (permalink) Old 11-17-2013, 01:37 PM
moose1's Avatar
You just stuff them under the seat
Sent from Motorcycle.com App
2012 FLTRU vivid black
moose1 is offline
post #5 of 10 (permalink) Old 11-17-2013, 02:35 PM
Banned
^^^^^ spot on. I ziptie them the best you can right under the seat and stuffed in the little space left
Scootin is offline
post #6 of 10 (permalink) Old 11-17-2013, 07:59 PM
REDRUM's Avatar
Yep...rolled them up with Velcro straps under the seat...fits quite nicely and I have the SG/RGC custom seat on my RGU.
2013 Ember Red Sunglo Roadglide Ultra. Mod thread
REDRUM is offline
post #7 of 10 (permalink) Old 11-17-2013, 08:15 PM
RoadGlideRider's Avatar
First, I installed the Hidden antennas (AM/FM and CB) in the fairing.
This meant two less wires to worry about when dealing with the Tour Pak.
Next I moved the passenger headset plug to the side of the Docking hardware. (See second photo)
All you need a clip to secure to the front Docking bolt (HD #10036). Passenger still has Music.
(If you want to use the switch housing I used here is a part number, 77133-09. It will plug into the Lt speaker plug)
Next I took the four speaker wires to the right and used a Duetsch plug, like for the Accessory plug.
The left has the factory plug for the Tour Pak lights. Both tuck under the seat when not in use.
Clean and easy to add and remove the Tour Pak. Wires left tuck neatly under the seat.
peterg13 likes this.
RoadGlideRider is offline
post #8 of 10 (permalink) Old 11-17-2013, 09:32 PM
There's an excellent thread on hdforum that goes into great detail with pictures on how to put the deutch connectors on the wires going to the tourpak so that the bulk of the wires stay with the tourpak instead of staying on the bike. Also include the BNC connector pictures if you want to keep the FM and CB antennas instead of going to the faring mounted ones if you prefer. http://www.hdforums.com/forum/tourin...etachable.html.
rabell is offline
post #9 of 10 (permalink) Old 07-10-2016, 12:11 AM
Shadow Reaper's Avatar
Originally Posted by rabell View Post
There's an excellent thread on hdforum that goes into great detail with pictures on how to put the deutch connectors on the wires going to the tourpak so that the bulk of the wires stay with the tourpak instead of staying on the bike. Also include the BNC connector pictures if you want to keep the FM and CB antennas instead of going to the faring mounted ones if you prefer. How to make your tourpak on your UltraClassic Quick Detachable! - Harley Davidson Forums.
i know this an old thread, but i followed this guide and damned if it didnt work out great, simplifies disconnecting my 2013 FLTRU tour pack
Four wheels move the body. Two wheels move the soul.
Shadow Reaper is offline
post #10 of 10 (permalink) Old 07-15-2016, 02:08 AM
Stuffed under solo seat lots of room
Rick 2016 RGU Vivid Black
Reccerick19 is offline
Tags
detach kit , tour pack , wires
SE Phat Plug Wires or OEM Plug Wires wevsspot *General Road Glide Discussions/Pictures 31 07-07-2017 11:17 AM
wires for tour pack wayne Aftermarket Accessories 6 03-24-2015 07:55 PM
Tour Pack Wires ? WJW67 Seating: seats, backrests 7 06-15-2014 06:24 AM
Do wires need extended on a '10 RGC for 16's? kyle31490 Controls & Handlebars 11 05-02-2014 06:12 PM
OK, do I need to do something with the back of my tour pack? ChromeYellow67 *General Road Glide Discussions/Pictures 90 12-05-2012 07:35 AM
