No cruise or brake lights - Road Glide Forums
post #1 of 4 (permalink) Old 08-21-2011, 11:33 AM Thread Starter
Bike is an 07 road glide, found a blown fuse for the brake/cruise, replaced it and the new fuse blew again.
Going out to start checking things out, anyone have his problem, and suggestions on where to look ? will start with the front and rear brakes, but was wondering if the brake relay in the left side fuse box could have blown ?
any help or suggestions appreciated.
Thanks
pigfixer is offline
post #2 of 4 (permalink) Old 08-21-2011, 01:27 PM
Redfish-Joe's Avatar
Have you replaced the bars or put new grips or controls on? Could be a pinched wire on the right side.
Redfish-Joe is offline
post #3 of 4 (permalink) Old 08-21-2011, 02:47 PM Thread Starter
No haven't changed the bars but have adjusted them, I'm pulling the switch apart now to have a look.
thanks for your help
pigfixer is offline
post #4 of 4 (permalink) Old 08-21-2011, 11:18 PM Thread Starter
what I found
well, the aftermarket tail light had a short in it, so that was the cause of no brake lights or cruise, and why the blown fuse's, yea it took a few to find it.
But I also found that the rear brake light switch was bad, stuck closed, where the brake light was always on.
Anyway, that's how I spent my day and what I found. Everything seems to be working correctly now...
pigfixer is offline
No Turn Signals, Running Lights, or Brake lights on 15 FLTRXS warbird458 Lighting 5 07-12-2016 08:02 AM
red cruise light, no cruise piggs Troubleshooting for Road Glides 1 05-08-2014 06:47 PM
No 6th gear light, no cruise scsharp2260 ECM/Fuel Management systems 5 01-17-2013 03:14 PM
no turn signals, brake lights, or power to cruise MoRob Troubleshooting for Road Glides 4 07-02-2012 10:23 PM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 06:02 PM
