Oil Change Question - I gots leaks! - Road Glide Forums
post #1 of 12 (permalink) Old 08-25-2011, 09:40 PM Thread Starter
So here we go. 2011 RGU.
At 50 miles, drained all 3 cases and replaced with H-D Dino in the crankcase and H-D Syn3 in the Trans and Chain. New Filter
At 1000 miles, drained the crankcase and replaced with HD-Dino. New Filter
At about 4.5K miles, drained the crankcase and replaced with HD-Syn3. New Filter
Now, I got drips and leaks everywhere. Both the Trans and Crankcase plugs drip, and I got drips forward under the filter. The bolt and compression washer above the crank drain bolt drips too, and I never even touched that one. The entire undercase is wet.
I did replace the o-rings, but I did not teflon or otherwise prep the threads on the drainbolts.
What gives, and what did I screw up here. More importantly, whats the best way to fix? Teflon the threads?
Thanks in advance.
Al
Southern NH
2011 Road Glide Ultra
2005 Concours
mdwar2005 is offline
post #2 of 12 (permalink) Old 08-25-2011, 09:59 PM
Thanks in advance.
are you sure it is just not oil blowing back from the oil spilled when you changed the filter?
jeff is offline
post #3 of 12 (permalink) Old 08-25-2011, 10:28 PM Thread Starter
Some could be blow-back, (especially up front) but I'm consistently seeing fresh drips from the oil and trans drain bolts. I've also cleaned the underside on several occasions. I also have about 1000 miles on since my last o/c, so I figure anything that has blown back should of already done so.
Just cleaned it again, and am gonna look again tomorrow night.
Al
Southern NH
2005 Concours
post #4 of 12 (permalink) Old 08-25-2011, 11:08 PM
I would check to see if the o rings have been pinched or torn during the installation. they could have also been under or over torqued. I would recommend lubricating the o rings as well. I'm no experienced HD mech, but I do know a thing or two about turning wrenches on helos, and there's a ton of o rings on those bad boys.
I am here: http://maps.google.com/maps?ll=33.224077,-117.319603
PhrogFlyer is offline
post #5 of 12 (permalink) Old 08-25-2011, 11:32 PM
dikdark's Avatar
And blowing a seal on a whirlybird at a couple thousand feet doesn't mean pulling over and calling for a ride.
What about the filter seal? It just seams freaky that both the oil and tranny plugs would start leaking at the same time. Do you have an oil cooler? Try getting everything cleaned off then take a short ride and check. Might be able to trace the leak back to the origin before the leak gets blown all over the place.
07 RG Vivid Black
FLHX fascia
Stage 1, SE pipes DS baffles,
+2 Sweepers, chrome quickly fading to black
dikdark is offline
post #6 of 12 (permalink) Old 08-26-2011, 09:21 AM
Crossthreaded plugs? Would cause leaks or the o rings are pinched or torn as stated earlier.
BigDum is offline
post #7 of 12 (permalink) Old 08-26-2011, 08:24 PM
Redfish-Joe's Avatar
Apply teflon tape to the threads also. I know it's overkill and the o-rings should hold, but an ounce of prevention.....
Redfish-Joe is offline
post #8 of 12 (permalink) Old 08-26-2011, 08:40 PM
hotrodad's Avatar
spray brake cleaner all over the front where you spilled the oil, under where its collected and dripping from then blow it all off with compressed air. Now you start clean and see where the oil is dripping from.
Hard to believe you got all those leaks show up just from an oil change.
good luck
2005 FLTRi
Black Pearl
Live to Ride ~ Ride to Live
hotrodad is offline
post #9 of 12 (permalink) Old 08-27-2011, 09:09 AM Thread Starter
Looks like it's just the Tranny plug. Cleaned it thoroughly and put 100 miles on, then let it sit for a night. One drip spot only. Thanks for the advise. This is my first time dealing with these silly little O-rings. All my metrics before just used crush washers and I've never had an issue like this. I'll lay even money I ripped the o-ring when I re-installed the plug.
Al
Southern NH
2005 Concours
post #10 of 12 (permalink) Old 10-09-2011, 09:41 AM Thread Starter
Update. It wasnt the tranny plug. The leak came back on me. Ive been busy and the bike hasnt moved in a month. I know...bad,bad,bad. Took it out for a short errand and the exhaust is smoking. Wtf. Look underneath and the entire undercarraige is coated with oil. Ended up that the two bolts that hold the exhaust hanger underneath the tranny cover were very loose. The bolts are in a very inconvenient location, but after a bit of swearing, i was able to snug them up. Dont know if they were undertorqued from the dealer or what, but if this helps someone else who has the same issue, then its all good.
Al
Southern NH
2005 Concours
2013 RG Ultra with 500 miles transmission leaks MurphyPeoples Troubleshooting for Road Glides 5 05-27-2014 02:01 PM
Leaks on its Jiffy Stand but not on the Center Stand Minivend Troubleshooting for Road Glides 8 10-16-2013 10:19 AM
exhaust leaks SmokeyJoe Intake and Exhaust 8 03-10-2013 05:19 PM
Loss from oil leaks Sancho *General Road Glide Discussions/Pictures 11 04-09-2012 10:26 AM
primary leaks jprider4life *General Road Glide Discussions/Pictures 3 03-13-2012 07:53 AM
