08 Fltr Running like crap again.....help! - Road Glide Forums
post #1 of 11 (permalink) Old 08-26-2011, 06:13 PM Thread Starter
skipperfltr's Avatar
Once again, she started popping and coughing, hard start also. The last time it turned out to be plugs, so I went to the local parts store and we agreed they look a little lean, but I bought a cooler set and installed, she ran decent untill I got it home. Then she wouldnt hardly start again, I took off the air cleaner to check it, and just for giggles, I put a rag over the intake while it was running, and it kept running! Then I put my hand over the hole and she still ran! I'm thinking intake leak, but would greatly appreciate any input, thanks, Skip
50 States on a bike at age 50.
skipperfltr is offline
post #2 of 11 (permalink) Old 08-26-2011, 06:23 PM
JacktheBagger's Avatar
Is what it sounds like to me as well
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 11 (permalink) Old 08-26-2011, 09:30 PM
Did you change the fuel lines inside the gas tank or the fuel filter housing? It ia a common problem for the fuel lines inside the fuel tank to develop cracks, the 08 models had a recall on the fuel filter housing because the cover of the fuel filter housing would get out of round, both conditions will cause air to get into the fuel lines. If there is air in the fuel system the bike will run bad, the bike will pop & backfire and also there will be a lack of power.
post #4 of 11 (permalink) Old 08-27-2011, 12:05 AM Thread Starter
No Ironmark, I did not know that, However, I've replaced it twice, last time at 53k, I am now at 56k,and as you may know, it is a pain in the [email protected]# to pull it for inspection, but I will if all else fails. Thanks.Skip
post #5 of 11 (permalink) Old 08-27-2011, 08:05 AM
Gonekat's Avatar
vacuum line broken
I had similar experience with my 07 FXSTC. It ran terrible, and i did the same thing by changing the plugs and removed AC. It turned out that one of the vac hoses behind the throttle body had cracked and torn. i went to Autozone and for .18 i had an entire foot of it. Replaced it and she purrrred like a kitten.
Gonekat is offline
post #6 of 11 (permalink) Old 08-27-2011, 11:10 AM
Redfish-Joe's Avatar
Spray some WD40 around the intake gaskets while it is running. If it smooths out it will be an intake gasket. Don't worry about the excess WD40 soon dissipate due to the heat.
Redfish-Joe is offline
post #7 of 11 (permalink) Old 08-27-2011, 03:51 PM Thread Starter
I tried the wd-40 trick last night with no change in rpm at all, let it sit, this morning I ran her out about 3 miles away to do an errand, as soon as it hits operating temp it starts, a little pop here, then a slight hesitation on acceleration,etc. By the time I dropped off my package and got back to the house, I had the emergency flashers going, and ran every red light because if the rpms went below 2500-3000, the damn thing would shut off, then I would play hell getting it started again. Thats another thing, to restart it when this happens takes full throttle, can you believe that crap? It barely made it up on the lift running. ##@#@%@@^%&*^*
post #8 of 11 (permalink) Old 08-27-2011, 03:56 PM
OK runs fine when cold. The warmer / hotter it gets the worse it runs. Could be the coil pack. As the coils heat up they could be creating an open state causing the miss fire.
post #9 of 11 (permalink) Old 10-02-2011, 11:14 AM
What bike do U have? Suggest listing bike in your signature
2009 FLTR Road Glide. Total stock - and gonna keep it that way!
OOPS!!!! After 15K miles I couldn't stand it any longer. Installed Fuel Moto's 09 Touring Package, ie; JP Tuned Muffs, SE Air, PV Tuner......0809-96-JPSlipons-205.pvt
tlippy is offline
post #10 of 11 (permalink) Old 10-02-2011, 11:49 AM
BDMastiff's Avatar
I had a similar issue when I had my 07. Ended up I had a small crack in my pipe. My friend at RB Racing gave it a weld and the issue was gone.
This post is titled 08 fltr running like crap again. I'm guessing he has an 08 Road Glide.
1996 Fatboy
BDMastiff is offline
Hoply crap I need help 423springer Troubleshooting for Road Glides 7 07-13-2016 09:11 PM
Anybody else having problems with there black dragos dragula looking like crap? pat123 Intake and Exhaust 25 10-30-2014 07:58 PM
New 2014 runs like crap with PCV Brianu1 ECM/Fuel Management systems 10 06-04-2014 10:52 PM
Engine Running Like Crap runnhrd *General Road Glide Discussions/Pictures 10 04-21-2012 07:41 AM
Took my bike out west and now runs like crap Ozoneman *General Road Glide Discussions/Pictures 25 09-12-2011 06:34 PM
