Front rotor warp? Need technical input! - Road Glide Forums
post #1 of 15 (permalink) Old 08-27-2011, 03:25 PM Thread Starter
zman's Avatar
I have a aggravating brake pulse in the front wheel brake. Suspected a warped rotor but when I checked it with a indicator it shows a max of .007" run-out. I was thinking of ordering a new rotor but I would not think that .007" would be enough to be an issue. Any thoughts?
BTW: I'm running a single front rotor with stock 4 piston caliper on an 06.
"I Just Cant Leave Well Enough Alone"
zman is offline
post #2 of 15 (permalink) Old 08-27-2011, 03:30 PM
Redfish-Joe's Avatar
Just a guess here. Single non floating rotor would be a little more aggressive in the pulsing than with two rotors.
Redfish-Joe is offline
post #3 of 15 (permalink) Old 08-27-2011, 03:44 PM Thread Starter
zman's Avatar
Yea, I'm weighing the option of upgrading to 13" floating rotor with 6 piston Hawg Halters. A lot of money but that would most likely be the long term solution.
zman is offline
post #4 of 15 (permalink) Old 08-28-2011, 09:46 AM
It doesn't take much run out for you to get a pulsation in the brakes. The best way to fix it is to just get a new rotor, the rotors can be turned but it is not really worth the time or money.
post #5 of 15 (permalink) Old 08-28-2011, 10:20 AM
tmd
If your going to run a single rotor you need to upgrade to a larger diameter disc and caliper or go back to the duals. A RG is too much bike for a single stock sized disc up front. Even if you replace it, one hard stop with it hot is going to warp it again.
tmd is offline
post #6 of 15 (permalink) Old 08-28-2011, 01:04 PM
Rowdy's Avatar
I believe the spec on replacement from HD is .008. I had one at .007, and the other at .003, it pulsed in a big way. I bitched till they switched them out. Running a single rotor set up I would thnk your getting a big pulse. Personally I would pull the trigger on a new roter, and change it out.
Rowdy
Rowdy is offline
post #7 of 15 (permalink) Old 08-28-2011, 04:35 PM Thread Starter
zman's Avatar
Thanks guys for the input. I'm probably going to get a new rotor this week.
Z
zman is offline
post #8 of 15 (permalink) Old 08-28-2011, 05:23 PM
staush's Avatar
Make it a floater. Can't go wrong, even a little warp will pulse without a floater.
staush is offline
post #9 of 15 (permalink) Old 08-30-2011, 07:13 PM
Rotor replacement
My 2011 RGU has been pulsing for awhile 14,300 miles today.HD dealer said brakes are not covered under warrenty.I went to the sales manager later a complained about the service advisors comment.Mechanic rode my bike in the parking lot and agreed with me on warped rotors.They were changed this morning.Bike is braking smooth now.
John Nash is offline
post #10 of 15 (permalink) Old 08-30-2011, 08:09 PM Thread Starter
zman's Avatar
Well, you guys are going to think that I'm a real McGiver, very cheap, crazy, Or all three.
I removed the caliper so I could get an accurate reading with the indicator. I found the warp to be in one spot. I slightly loosened the corresponding rotor bolt and the warp suddenly drop to .002" runout from .007". Made a small .002" shim, slid it between the hub and rotor at that bolt, tightened everything up and checked it again; .002" runout.
Went on a test ride, no pulsation!
Yea!
zman is offline
Harley technical blueprints hotrodad General Off-Topic Discussions 1 11-21-2013 06:23 AM
Alarm technical help! ctalbot6983 Troubleshooting for Road Glides 5 01-05-2013 07:54 PM
2013 Harley-Davidson Motorcycles New Product Technical Cosmic Charlie *General Road Glide Discussions/Pictures 7 01-03-2013 09:55 PM
Anyone ever had a brake disc warp? SurlyBoy Wheels and Tires 26 10-18-2012 05:56 PM
New Wheels on ABS bike - Technical Question twalte Aftermarket Accessories 3 09-02-2011 01:29 PM
