oil pressure! - Road Glide Forums
post #1 of 11 (permalink) Old 08-29-2011, 07:44 PM Thread Starter
Blackrg's Avatar
oil pressure!
No oil pressure showing on gauge, I do have oil pressure though. Just installed Dakota digitals, set it for correct sensor too. Called them.... no help.
I took off the fairing again and checked everything then installed the oem gauge and still nothing.
Thought maybe bad sending unit, bought that installed and no go! Anything else to check I dont know about?
2010 FLTRX Fuel Moto 107, Heavy Breather,SE tuner,RC components 21 in front wheel, single disc matching rotor, PM calipers,Progressive monotube front, Dakota digital, Hogg Chopps, Sancho wings, 10 inch mini apes, Bannana boards. V&H true duals and boomcans.Don't pick a fight with an old man. If he is too old to fight, he'll just kill you.
Blackrg is offline
post #2 of 11 (permalink) Old 08-29-2011, 10:50 PM
CHAINSAW's Avatar
How are you sure you have oil pressure?
Such is the rule of honor.
CHAINSAW is offline
post #3 of 11 (permalink) Old 08-29-2011, 11:16 PM
DemonCity's Avatar
Bikes running! Lol!!!
1%DFFD1%
DemonCity is offline
post #4 of 11 (permalink) Old 08-29-2011, 11:44 PM Thread Starter
Blackrg's Avatar
Well yes it is running and it runs fine 200 -230 around town today.
It runs the same sounds the same no issues there so I'm assuming I have oil pressure . Since I replaced the sender thought maybe i was missing something.I'm guessing some sort of wiring issue just thought I'd ask.
Blackrg is offline
post #5 of 11 (permalink) Old 08-30-2011, 07:46 AM
EdY39's Avatar
If the oil pressure light is not coming on, the problem has to be with the Dakota gauge. Install the stock gauge back in and see if it shows pressure.
Ed
2002 RoadGlide
DPCM, USN (Retired)
EdY39 is offline
post #6 of 11 (permalink) Old 08-30-2011, 09:37 AM
bad ground ?
ROADEAGLE is offline
post #7 of 11 (permalink) Old 08-30-2011, 01:42 PM
Originally Posted by ROADEAGLE View Post
bad ground ?
Many electrical problems seem to lead to a bad ground.
Seadog is offline
post #8 of 11 (permalink) Old 08-30-2011, 02:59 PM
Wow.
I guess you should check continuity from the sending unit to the gauge. No power. Disconnected both ends. If it's zero ohms try and figure out where the circuit gets ground. It would be the engine on that end. Separate wire on the other end, inside all that plastic, going to a ground somewhere.
Good Luck
Edy39 - He DID cross check it with the oem gauge... No joy.
FGOWI is offline
post #9 of 11 (permalink) Old 08-31-2011, 05:33 PM Thread Starter
Blackrg's Avatar
Well it seems if you switch the connectors it works fine. I had the volt gauge connected to the oil pressure . Numbnuts I guess.
Blackrg is offline
post #10 of 11 (permalink) Old 08-31-2011, 06:00 PM
For you folks who don't do this type of work for a living I have one tip .... Label your parts and wiring when removing .
High Oil Pressure and High Oil Temps ironmark Troubleshooting for Road Glides 17 12-09-2012 10:44 AM
use of a oil pressure gauge for air psi??? bigeyed76 Equipment-RG 9 03-11-2012 11:31 PM
oil pressure question dennisnyhc *General Road Glide Discussions/Pictures 5 03-18-2011 09:00 AM
Oil Pressure dhhen Troubleshooting for Road Glides 11 12-07-2010 11:50 PM
Oil pressure gauge 2010fltrx Troubleshooting for Road Glides 1 08-16-2010 04:09 PM
