Rear Breake feels like it needs bleeding - Road Glide Forums
post #1 of 4 (permalink) Old 08-30-2011, 01:17 AM Thread Starter
1st Sgt's Avatar
5000 miles on the 2011 (with ABS) Rear brake feels soft - ie pedal travels further downward but can still cause the ABS to engage if I push hard enough. - if i pump the brake once it engages the brake quicker. I bled the brake but no change in the symptom - anyone else with this issue? Did i bleed it incorrectly? (pump the pedal, keep pedal depressed, crack open the bleeder valve, close the valve, release the brake pedal)
1st Sgt is offline
post #2 of 4 (permalink) Old 08-31-2011, 12:28 AM Thread Starter
1st Sgt's Avatar
Really!? no comments/pointers on this one (besides learning how to spell brakes)
1st Sgt is offline
post #3 of 4 (permalink) Old 08-31-2011, 08:20 AM
Gadgetech's Avatar
That's how I've always bled the brakes but that travel does seem to be a bit far. Have you thought about using a bleeder tool?
2017 RGU Black Quartz
2014 Ducati Multistrada Granturismo
Gadgetech is offline
post #4 of 4 (permalink) Old 08-31-2011, 09:19 AM
Rowdy's Avatar
With ABS, you may just have to use a bleeder tool. There was a rumor that an HD shop had to bleed brake systems with ABS, and then I know I saw some posts saying that it was in untrue, and that they had done it (on the front after installing bars/cables etc.). Hopefully someone will chime in here for ya with a tech tip.
Rowdy
Rowdy is offline
Feels Like Bad Gas david-h Troubleshooting for Road Glides 0 10-23-2013 09:07 AM
So that's what it feels like PGR *General Road Glide Discussions/Pictures 69 10-11-2013 01:06 PM
Feels like prison TLKurtz *General Road Glide Discussions/Pictures 46 05-04-2013 09:13 AM
Feels like the front end has a wobble to me irharley Videos 1 11-04-2011 10:10 AM
