Lower Fairings - Road Glide Forums
post #1 of 9 (permalink) Old 09-05-2011, 08:19 AM Thread Starter
Lower Fairings
What do you have to trim in order for a vented lower fairing to fit on my 09 Road Glide. If buy a used set and have to get it painted anyway, I was thinking maybe I should trim it and then paint it, if I can, and then just put it on. It would be much easier than taking everything off again (did it for my painted inner fairing).
2009 Hot Red Sunglo, 107 build, S&S 551 cams, heads polished and ported, Vance & Hines Dresser Duals, Vance and Hines 4" rounds, REVOLUTION PERFORMANCE ems, Bad Seed bars, J&M amp and rokkers speakers, Sony DSX-S310, progressive 940's
RoadGlide0611 is offline
post #2 of 9 (permalink) Old 09-05-2011, 05:41 PM
Too Short's Avatar
Instead of trimming you can go buy the fairing mounts that raise the fairing the inch required to use the vented lowers.
2010 FLTRX Black Denim "Lola Montez"
Too Short is offline
post #3 of 9 (permalink) Old 09-05-2011, 07:28 PM Thread Starter
Don't you have to take the inner and outer fairings off?
post #4 of 9 (permalink) Old 09-05-2011, 08:39 PM
Too Short's Avatar
To be honest with you, I'm not 100% sure. I know I've either seen the answer to this question on this forum, or the OTHER forum. My response was just from a personal stand point. I'd rather install them the right way with the lift than do any "trimming". When I do things like that, they don't always turn out right. I'm sure if you researched it a bit, or talked to the folks that have had their glides way longer than me, you'll find the answer you're looking for. Sorry I couldn't be more help.
post #5 of 9 (permalink) Old 09-05-2011, 10:59 PM
skratch's Avatar
the trimming you're referring to is that part of the cap that runs along the top of the crash bar. the newer fairing lowers come with that already shortened. the problem that you are gonna have, even if you do trim that piece, is that the older (like 09 is old now ) fairings sit lower so that there will be either very little clearance between the lower and the fairing, or it will actually hit it. i say either because i have seen both. i guess all bikes don't come from the factory exactly the same....
the best way to do it would be to buy the 3 pieces required to lift the fairing up, and give it that little forward tilt. it isn't very expensive, and doesn't seem like it would be that hard to do, but i'm sure it would intimidating if you have never removed the fairing before. don't have the part numbers handy, but search for it on here, several folks have done it.
skratch is offline
post #6 of 9 (permalink) Old 02-27-2014, 07:22 AM
opr1945's Avatar
so only the caps have to be ground down , not the fairing itself?
opr1945 is offline
post #7 of 9 (permalink) Old 02-27-2014, 07:28 AM
No grounding the caps....
What year bike do you have and what lowers are you looking at?
Sent from my SPH-L710
post #8 of 9 (permalink) Old 02-27-2014, 10:46 AM
opr1945's Avatar
I have a 2009 road glide base. havent bought lowers yet. would prefer to go with newer vented lowers. but would be ok with older non-vented lowers. which ever is the easiest to do. I feel reasonably comfortable making minor reductions to the tops of lower fairing/caps. Less so with changing the fairing mounting bracket, the two engine gurard brackets don't look like much of a challange.
opr1945 is offline
post #9 of 9 (permalink) Old 02-27-2014, 11:14 AM
Changing the fairing mounting brackets are real easy it is just a little time consuming. Go with the vented fairing lowers you will be much happier than doing the non-vented.
I only takes around 3 hours and a few beers to swap out the upper fairing mounting brackets and that is taking your time.
To begin with you do not have to remove any of the gauges or the speakers they will come out with the inner fairing. You only need to pull the radio which only has 4 bolts.
Label the gauge wires because the plugs are typical but all the other plugs are plug specific (male only fits correct female). Take a few pics of the wiring will help you run the wires in the right place when putting things back together.
If you buy new fairing lowers get the 2010 and later fairing lowers because they fit right up without any trimming or cutting, 2009 and earlier vented fairing lowers were made for batwing bikes and would require trimming of fairing cap. You can also order the new fairing lowers already painted to match.
I did this upgrade to my 2008.
WTB Lower fairing top U clamps to fasten the lower fairings to the crash bar. hogger Wanted! (Buy or Trade) 12 05-20-2012 06:46 PM
Need ideas on lower fairings install SharkNose *General Road Glide Discussions/Pictures 6 01-10-2011 08:55 PM
Speakers for the lower fairings firecap1962 *General Road Glide Discussions/Pictures 28 12-05-2010 02:42 PM
Vented Lower Fairings chryssmt Aftermarket Accessories 20 11-09-2010 01:49 PM
question about buffeting with lower fairings on Weekendwarrior Windshields 12 07-11-2010 12:36 PM
