Starting problem - Road Glide Forums
post #1 of 8 (permalink) Old 10-08-2011, 02:22 PM Thread Starter
Starting problem
I have had my 2011 103" FLTRX for 2.5 weeks now and today for the second time in two days it acted like it did not want to start. I would hit the start button and it would just crank and I let off around 5 seconds, this was repeated until it started about 4 seconds into the third try. It has at least 1 gallon of gas in it and temp is mid 70’s. Unfortunately I only have 500 miles on it so far between the job and two side businesses just don’t get a lot of riding in.
I did manufacture a bracket for my adjustable back rest since there needed to be a third tie down point. The bracket is bolted to the frame and sits under the two bolts that hold down the electronics package that sits on top of the battery. Is there any way that that raising the rear mounting point of the electronics 3/16” could have caused this?
Thanks in advance for the help.
Black Sheep is offline
post #2 of 8 (permalink) Old 10-08-2011, 02:28 PM
Admin
BillyBob's Avatar
Sounds like maybe a battery issue.
Try putting a trickle charge on the battery and see if that helps.
Sent from the Droid using Tapatalk
BillyBob is offline
post #3 of 8 (permalink) Old 10-08-2011, 08:35 PM
Govdog76's Avatar
I agree with admin. Something definitely amiss. If you do not ride often/far then you are probably draining your battery and not getting good amperage when you want to crank.
That being said, it is still under warranty and there is no reason for a stock 2011 bike to be as hard to crank as you describe, so you could just take it to the dealer and let them figure it out.
Good luck and let us know what happens.
Ian
Govdog76 is offline
post #4 of 8 (permalink) Old 10-08-2011, 09:11 PM
cestaro's Avatar
check the battery connections
cestaro is offline
post #5 of 8 (permalink) Old 10-08-2011, 10:39 PM
Hard to Start
It takes 4-5 seconds to start mine when its cold even if the ambient temp is 80 degrees.When its hot or even warm fires right up . I talked to the dealer and they said thats normal. But my 09 always fired right up. I think there is something letting the fuel pressure drop after sitting for a while. Im going to do alittle more research before going back to the dealer.
smitty is offline
post #6 of 8 (permalink) Old 10-09-2011, 08:39 AM Thread Starter
hard to start
Thanks for the input I will check the battery and connections, not ready to take it to a steeler yet.
post #7 of 8 (permalink) Old 10-09-2011, 08:40 AM
Sincecrazy's Avatar
Id have the fuel pressure checked. I had a bad fuel filter housing, which allows the fuel to bypass at the o-ring on the fuel filter cap, causing a loss of fuel pressure. This occurred under high rpm's, however, it could also allow the fuel filter to drain after sitting.
Sincecrazy is offline
post #8 of 8 (permalink) Old 10-23-2011, 09:10 PM
sportyguy69's Avatar
Do you wait till the sound of the fuel pump stops after you hit the run switch before you crank the bike? Try starting the bike before the sound of the fuel pump stops.
My bike cranks seems like forever if I left the fuel pump sound stop before I hit the start button.
Jamie at Fuel Moto gave me this piece of advice. Havent had a problem starting the bike since.
If your going to do something give it all you got, might be the last time you ever do it !!!
sportyguy69 is offline
Hard starting problem Tour Rider Engine Related 9 06-14-2016 01:10 PM
Problem starting at times Headbanger Troubleshooting for Road Glides 19 02-08-2015 04:05 PM
Initial starting problem spider445 Troubleshooting for Road Glides 7 03-15-2013 01:14 PM
Problem starting when hot. hoosierboarder Troubleshooting for Road Glides 2 08-02-2012 06:04 AM
04 starting problem WildBill Troubleshooting for Road Glides 4 07-05-2011 02:05 PM
