Wrapped the Cat with DEI Titanium Heat Wrap - Road Glide Forums
post #1 of 7 (permalink) Old 10-14-2011, 12:28 AM Thread Starter
Yesca's Avatar
I wrapped my Catalytic converter with DEI's Titanium heat wrap and it dropped the direct and radiant temps almost 200 degrees. Not sure if it will have any effect on other parts of engine or not, but it did make a noticeable difference in the radiated heat when stopped. The ETMS still kicks in when idling for too long, such as at a stop light, but the actual heat from the cat seems to be lower. Temp was measured using a thermo-couple connected to my DVM. Pre-wrap temp: direct = ~660 degrees, indirect = ~ 500 degrees measured at the center of cat on the inboard side. Post-wrap temps: direct ~ 450 degrees, indirect = ~ 340 degrees (engine idling for all tests). Need to maybe try wrapping all of the exhaust pipes or just go ahead and get the American Custom Exhaust Head pipe. I thought I could handle the heat from the cat, but its just not worth being uncomfortable if you don't have to be. I was wanting to keep it mostly stock for as long as possible since i have the extended warranty, but that heat has to go!
D
2011 FLTRU - Black -
SE Ventilator A/C, SE Thunder Street Mufflers, V & H Power Duals, Power Vision
Yesca is offline
post #2 of 7 (permalink) Old 10-14-2011, 12:34 AM Thread Starter
Yesca's Avatar
Oops...wrong thread.
Yesca is offline
post #3 of 7 (permalink) Old 10-14-2011, 12:35 AM
Grind's Avatar
Were you able to put the stock heat shield over the wrap?
2011 FLTRU Merlot Sunglo
CFRs, gilded pinstripes, Medallion Classic gauges
Grind is offline
post #4 of 7 (permalink) Old 10-14-2011, 07:26 AM
GLYDDN11's Avatar
Same question as Grind
The World ends when you're dead. Until then,
you got more punishment in store. Stand it
like a man....and give some back
GLYDDN11 is offline
post #5 of 7 (permalink) Old 10-14-2011, 12:42 PM Thread Starter
Yesca's Avatar
Yes, there is enough length on the worm-drive-clamp to re-install the stock heat shield.
Yesca is offline
post #6 of 7 (permalink) Old 10-14-2011, 12:46 PM
RGUrider's Avatar
I wrapped mine in cardboard and put it in my garage storage area. Dealer did the pipe swap so I EXPECT warranty to be honored.
RGUrider is offline
post #7 of 7 (permalink) Old 10-14-2011, 02:24 PM
1BigGuy's Avatar
I wrapped a set of FuelMoto 2 into 1 in the same heat wrap. As stated here you can put the heat shield back over the pipes. The only one where it was tough was right in the area where the pipe comes together and that might just be how I wrapped it. Fair warning on any wrapping of pipes, they will smoke for a short period of time (two to three good rides) from the wrapped area.
2010 FLTRX Black Denim
2007 FLSTN Vivid Black
1BigGuy is offline
Exhaust Wrap under heat shields question WTFranz Intake and Exhaust 6 01-10-2017 03:23 PM
New Exhaust Gaskets, Jims Gasket Installer, Black heat wrap tape longrides Parts for Sale 0 07-21-2015 08:10 AM
Exhaust wrap uner heat shield longrides Intake and Exhaust 25 09-10-2014 10:55 AM
to wrap or not wrap MidniteRyder Intake and Exhaust 9 01-15-2013 08:44 AM
Wtt d&d fat cat perforated baffle for wrapped perforated baffle jimmyray11349 Wanted! (Buy or Trade) 0 01-12-2013 12:02 PM
