Batt & Low Fuel light came on WTF - Road Glide Forums
post #1 of 2 (permalink) Old 10-17-2011, 07:54 PM Thread Starter
Cotton Hill's Avatar
This morning going to work, about 3 minutes into the ride my This morning going to work, about 3 minutes into the ride my Batt & Low Fuel light came (over half full) on looked at the Volt meter it showed about 11.75. I slowed an turned around then the idiot lights went off so I turned around again and rode to work 50 Mi.and everything seems fine. Was that a warning that my stator or ECM is going bad?
Cotton Hill is offline
post #2 of 2 (permalink) Old 10-17-2011, 08:50 PM
Triplej's Avatar
It could be as simple as a loose battery cable or bad/corroded electrical connection, etc. I would start with checking you battery cable ends (both ends of both cables) for good connections and then checking to see if you have any stored Diagnostic Codes.
Triplej is offline
Can I use my batt tender lead to power heated gloves? kyle31490 *General Road Glide Discussions/Pictures 10 04-10-2015 12:36 PM
Engine light came on and speedometer went dead for the second time in 2 months Clean&Sober Troubleshooting for Road Glides 5 12-11-2013 04:14 AM
WTF spring came off Jiffy stand ameleo *General Road Glide Discussions/Pictures 16 10-26-2012 02:36 PM
engine light came on jprider4life Troubleshooting for Road Glides 0 06-01-2012 12:16 PM
Engine Light and Batt Light come on at same time Hintontm Troubleshooting for Road Glides 8 05-12-2012 07:37 AM
