vibrations in the rear brake - Road Glide Forums
post #1 of 4 (permalink) Old 10-21-2011, 08:20 AM Thread Starter
2012 FLTRX
When I discovered the IDS (isolated drive system) I began to think that it had to be the cause.
Problem or wierd thing:
With clutch in and rear brake applied at about 40 MPH, I feel a vibration from the rear tire that feels like going over speed stripes as you approach a rural stoplight or the wakeup stripes along the edge of the interstate. The vibes are not quite as strong as the examples.
If the IDS is the source, I can't explain how.
Snazzy is offline
post #2 of 4 (permalink) Old 10-21-2011, 09:47 PM
What year bike & does it have ABS??
post #3 of 4 (permalink) Old 10-25-2011, 08:47 PM Thread Starter
It is 2012 without ABS brakes. The front brakes do not give the same vibrations.
Snazzy is offline
post #4 of 4 (permalink) Old 11-15-2011, 08:48 AM Thread Starter
The rear caliper is not free floating and in fact is bolted to the frame.
I'm feeling the engine vibrations!
End of subject.
Snazzy is offline
Brake Levers and rear brake pedal from 2010 FLTRX (STOCK) HUTMO Miscellaneous for Sale 4 03-03-2016 06:48 PM
Billet brake lever installed for rear brake HUTMO Do-IT-Yourself 1 12-27-2012 04:18 PM
Changed rear brake arm now almost no rear brake? ncbeast Troubleshooting for Road Glides 4 05-30-2011 10:13 PM
Good Vibrations ... NOT HD_Shock *General Road Glide Discussions/Pictures 16 05-29-2011 05:13 PM
