when I bought the 2013 fltrx, I didn't want cruise or abs, so there aren't either.. say what you will. but today while braking for a light the cruise light came on red. whatta you think? loose wire somewhere or phantom cruise.
If the ABS light just flashed and did not stay lit you probably deactivated the EITMS System by rolling the throttle forward during your braking.
With the ignition switch ON and the run switch set to RUN roll the throttle forward and see if the ABS light flashes green for you. If so, you just re- activated the EITMS system.
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
