How to check codes ? - Road Glide Forums
post #1 of 7 (permalink) Old 06-22-2014, 07:36 AM Thread Starter
Z-SHARK's Avatar
Tried searching for this.. Could someone give a step by step on how to check codes? And does it apply to most year bikes? Dealing with a 2004 myself.
Fill with Gas... Twist throttle... Enjoy Life
Z-SHARK is offline
post #2 of 7 (permalink) Old 06-22-2014, 07:55 AM
Have you tried Iron marks how-to in the sticky on this section ?
post #3 of 7 (permalink) Old 06-22-2014, 10:11 AM
The instructions are right under your nose!
post #4 of 7 (permalink) Old 06-22-2014, 11:48 AM
usraptor's Avatar
How to Find your Diagnostic Trouble Codes
The speedometer is capable of displaying & clearing speedometer , tachometer TSM/TSSM , HFSM , ECM , ABS Diagnostic Trouble Codes also known as DTC's . The radios DTC's are retrieved through the radio and displayed through the radio display .
1 - Turn the ignition switch to off & run/stop switch is to run .
2 - Push odometer reset button in & HOLD .
3 - Turn the ignition switch on and then release odometer reset button . The background lighting should illuminate & the speedometer needle should sweep it's full range & indicator lamps ( battery , security , low fuel , check engine and cruise ) should illuminate . The word "DIAG" should then appear .
4 - Push the odometer reset button once and you will see the selection menu "PSSPtb" with the first P flashing .
5 - Each letter represents a area of the diagnostics module . The module that is flashing is the one you are going to check . To move from one letter to the next you must push the odometer reset button one time . ( from P to S to SP to t to b and back to P , ect ect )
P = ECM
S = TSM/TSSM/HFSM
SP = speedometer
t = tachometer
b = ABS codes
6 - To get the DTC code in a area of diagnostics you should PUSH & HOLD the odometer reset button in for 5 seconds and the release . If there are any DTC's the code will be displayed or the word " none " will appear if there are no DTC's . Push the odometer reset button again to view any additional codes if they exist .
7 - Record the codes .
8 - If DTC's are NOT to be cleared , press and release the odometer reset button . Part #of module will be displayed .
9 - If DTC's are to be cleared for that module , PRESS & HOLD the odometer reset button until " clear " is displayed .
10 - Press and release the odometer reset button to continue to the next module .
11 - Turn the ignition switch off to exit the diagnostic mode
2013 RGU, Vance and Hines Prop pipe and Fuel pak, SE AC, Wild One Chubby bars, Mean City Cycle Seat, Bright Ass tail light and LED turn signals, plus lots of chrome billet parts!
usraptor is offline
post #5 of 7 (permalink) Old 06-22-2014, 06:02 PM Thread Starter
Z-SHARK's Avatar
Thank you
Z-SHARK is offline
post #6 of 7 (permalink) Old 06-26-2014, 02:01 PM
Send a message via AIM to rick-e-b
great info on the diagonistic codes. I'm printing that and putting it in my files. Thanks
rick-e-b is offline
post #7 of 7 (permalink) Old 07-24-2014, 10:03 PM
T-BO 399's Avatar
This just came in hand for me since my engine light came on on my way to work. Thank you for posting.
Sent from Motorcycle.com App
2009 FLTR, BLACK PEARL
T-BO 399 is offline
Tags
back fire , check codes , rich , running lean
How Do You Read Your Check Engine Light / Codes dirtbag Troubleshooting for Road Glides 14 05-26-2018 01:12 PM
Codes and more codes SmokeyJoe Troubleshooting for Road Glides 3 03-09-2014 01:56 PM
How do I check diag codes with Thundermax installed? SIG556 ECM/Fuel Management systems 2 09-07-2012 09:23 PM
Road glide error codes beachbum Troubleshooting for Road Glides 3 10-10-2010 01:56 PM
tbl codes swampfox Troubleshooting for Road Glides 1 08-23-2010 06:20 AM
