08 Steady Speed Stumbling - Road Glide Forums
post #1 of 7 (permalink) Old 06-22-2014, 09:31 PM Thread Starter
Hi guys, I've started noticing something strange when riding. If I am riding at a steady speed where I am barely on the throttle once up to a cruising speed my bike seems to have a stutter to it. Once I roll onto the throttle it responds fine and no stutter. It's fine while accelerating too. It only happens when barely on the throttle regardless of the actual mph. I recently put a set of apes on and soldered the green connector for the throttle. It did not do it right after the bars, began a few weeks later. I tried cruising with the cruise control set and the stutter still happens once on a flat stretch with not much load on it. Does the fact the stutter still happen in cruise control, does that rule out the throttle in the bars? I've been told maybe a dirty throttle body, bad spark plugs, bad fuel filter.... I'll throw some new plugs in it tomorrow and see what happens and go from there. Anyone have any ideas or have experienced this?? My bike has 34k on it.
V&H Exhaust//Stage 1 intake//6k HIDS//12" KW Flare//12" Buky Assaults// Arc Audio 125.2// Alpine 5 1/4 components// Alpine head unit//color matched gauges//chrome this chrome that
FLTRick is offline
post #2 of 7 (permalink) Old 06-22-2014, 09:55 PM
faststan's Avatar
Check the connections on your O2 sensors. Maybe change the fuel filter.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 7 (permalink) Old 06-22-2014, 09:59 PM
Replace your plugs and if you're able to change the fuel filter. These are often overlooked when servicing the bike.
post #4 of 7 (permalink) Old 06-23-2014, 08:24 AM
mocotom's Avatar
It never hurts to change the fuel filter but normally that will effect the heavier throttle loads more due to fuel demand. If you have no issues with acceleration but a slight stutter (usually a sign of lean a/f ratio) only at light throttle, I would check for an intake leak assuming you haven"t changed anything else like exhaust or intake.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #5 of 7 (permalink) Old 06-28-2014, 12:53 PM
Check your fuel pressures. I had a dyna that had a similar problem but it would backfire when I rolled into the throttle. Found a fuel line in the tank leaking causing my lean problem. Sometimes you can open the tank with it running and hear it if it has a leak Also look at the tps. Read it out with ohms while rolling the throttle if it goes o/l it has a bad spot
Slider1156 is offline
post #6 of 7 (permalink) Old 07-02-2014, 12:13 PM
This ^^^^^
bbass is offline
post #7 of 7 (permalink) Old 07-11-2014, 10:30 AM
Did you check to see if there are any codes?
bbass is offline
Calling Steady Eddie tj316 *General Road Glide Discussions/Pictures 13 08-07-2018 05:29 PM
Engine stumbling from idle... trainz71 ECM/Fuel Management systems 5 11-22-2017 10:23 PM
Bucking at steady throttle 3609Glide ECM/Fuel Management systems 13 05-10-2014 03:00 PM
2005 Stumbling Nino Troubleshooting for Road Glides 33 12-24-2010 01:10 PM
