motor noise - Road Glide Forums
post #1 of 6 (permalink) Old 06-23-2014, 07:10 PM Thread Starter
Wildmank99's Avatar
motor noise
http://youtu.be/nnRT0Z4LS30
2007 road glide with stage 3 kit and got noise from front cylinder noise is worse when driving. Changed out my exhaust gaskets and still making the noise. Maybe head gasket?? not sure any help would be great
Kevin
2007 road glide black pearl, 103 kit with aftermarket heads and cams, air ride, 2 to 1 bub pipe, and alittle bit of sounds
Wildmank99 is offline
post #2 of 6 (permalink) Old 06-23-2014, 07:17 PM
Triplej's Avatar
Can't tell what exhaust you have but are there any 02 Sensors bungs in the front pipe?If so check for tightness of the bung plug.
Triplej is offline
post #3 of 6 (permalink) Old 06-23-2014, 07:19 PM Thread Starter
Wildmank99's Avatar
its a bub 2to1 and there are sensors in there and they are tight.
post #4 of 6 (permalink) Old 07-02-2014, 05:55 PM Thread Starter
Wildmank99's Avatar
Found the problem the compression release came loose out of the head and caused a very bad leak.
post #5 of 6 (permalink) Old 07-02-2014, 08:41 PM
Triplej's Avatar
Thumbs up
That had to be a moment of relief for you glad ya found it.
Triplej is offline
post #6 of 6 (permalink) Old 07-02-2014, 08:43 PM Thread Starter
Wildmank99's Avatar
Yeah it was
Motor Noise Bluchevypick Engine Related 15 07-14-2013 10:48 AM
Hissing noise in motor????? Louster47 *General Road Glide Discussions/Pictures 15 05-11-2013 09:23 AM
motor noise xbohntr Troubleshooting for Road Glides 23 03-04-2013 12:13 PM
motor noise xbohntr Troubleshooting for Road Glides 4 02-28-2013 08:47 PM
HELP! New and odd motor noise! bad86ta *General Road Glide Discussions/Pictures 1 05-30-2012 08:42 PM
