Brembo issue? - Road Glide Forums
post #1 of 29 (permalink) Old 06-28-2014, 07:30 PM Thread Starter
Brembo issue?
Howdy all,
Just put a front wheel setup from an 11 streetglide on my 08 RG.
Rotors were warped badly on the OE wheel so I figured, what the hell,
I get a new wheel (18") and maybe a good set of rotors to boot. Well, the rotors are flat, except now I get a hell of a scrubbing sound from the left brake. Pulled it off and the inboard pistons are moving, however the outboard are not. The scrubbing sound is from the caliper itself rubbing on the rotor. The pistons that are not moving are causing the caliper to shift over and the bosses that the pads ride on are being ground down. What the hell is going on is obviously above my pay grade. Anybody care to guess?
I'm scratching my head on this one.
And hey, the wheel was only $100.00.
Keith
Damn it Jim, I'm only a parts guy! Lol!
toyotapartsabq.com
Rte 66 Road Glide is offline
post #2 of 29 (permalink) Old 06-28-2014, 07:45 PM
93-331-29psi's Avatar
Did you replace the pads?
Sent from Motorcycle.com App
93-331-29psi is offline
post #3 of 29 (permalink) Old 06-28-2014, 08:16 PM Thread Starter
Yes, today.
Also cleaned the calipers real good. Pumped up the pistons and cleaned around the edges real good with brake cleaner. And as a side note.
I clamped each side down and pumped the M/C and the darn things move, just not when assembled??
Almost like it has air trapped on the one side?
toyotapartsabq.com
post #4 of 29 (permalink) Old 06-28-2014, 08:59 PM Thread Starter
Photos, hot off the bike, literally!
I even centered the pistons last time I put the caliper back on.
toyotapartsabq.com
post #5 of 29 (permalink) Old 06-28-2014, 09:01 PM Thread Starter
And another....
toyotapartsabq.com
post #6 of 29 (permalink) Old 06-28-2014, 09:32 PM
kouack's Avatar
Look like spacer are not installed properly on the shaft ?
kouack is offline
post #7 of 29 (permalink) Old 06-28-2014, 09:53 PM
As well as possibly a spacer in wrong you may want to get the install procedure for a wheel for an 11 streetglide there may be something in the install alignment that is causing your issues .
Eagle is offline
post #8 of 29 (permalink) Old 06-28-2014, 10:37 PM
Something ain't right, your pads should be way out past the area thats being ground down. Do you have a manual ?
post #9 of 29 (permalink) Old 06-28-2014, 10:43 PM
Is it doing that on both calipers or just one? I know 09 and up wheels are compatible but are you sure 08s are? Did the brake pad get wedged somehow when you put it back together?
post #10 of 29 (permalink) Old 06-28-2014, 11:20 PM Thread Starter
According to what research I did it should be a direct bolt on, and it did bolt right on. I am suspecting at this point the caliper may have an issue. It is like the balance of pressure pushing the pistons outward is not right. I will get some DOT 4 tomorrow and try bleeding? I don't believe it is any kind of spacer issue because it's not an alignment problem. The calipers bolted right up, no problem.
toyotapartsabq.com
Brembo Brake Issue Hammer Down Troubleshooting for Road Glides 9 08-05-2015 12:49 PM
Brembo Left Side Caliper - $149 v-rodder Classifieds Archive (3 months old+) 0 06-08-2011 08:11 AM
WTB- Brembo calipers 2whlr4life Classifieds Archive (3 months old+) 3 01-19-2011 11:49 AM
Pair of 08 Up stock Brembo front rotors sprint12 Classifieds Archive (3 months old+) 2 01-18-2011 06:52 PM
Brembo brakes oldskool Aftermarket Accessories 8 11-17-2010 06:22 AM
