clunk-clank - Road Glide Forums
post #1 of 8 (permalink) Old 07-05-2014, 01:59 PM Thread Starter
clunk-clank
Did a small wiring job, got bike back together and started it up to make sure I had not run down the battery.
I put the bike in gear (clank-normal). I let the clutch out slowly, and find.
Then I half popped the clutch. That is, I did not fully engage but rapidly let out the clutch just enough to engage the trans. I hear a loud clunk-clank combination. I can repeat this every time I try it.
I do not give it much if any throttle.
Normal?
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #2 of 8 (permalink) Old 07-05-2014, 02:49 PM
FDR's RGC's Avatar
Sounds like a compensator going bad. How many miles?
FDR's RGC is offline
post #3 of 8 (permalink) Old 07-05-2014, 03:46 PM Thread Starter
Originally Posted by fdr's rgc View Post
sounds like a compensator going bad. How many miles?
sent from motorcycle.com free app
3,800
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #4 of 8 (permalink) Old 07-05-2014, 04:31 PM
ERod62's Avatar
More info on work done and upgrades.
Not normal releasing the clutch and hear such clank noise.
Compensator could be an issue.
Sent from Motorcycle.com App
ERod62 is offline
post #5 of 8 (permalink) Old 07-05-2014, 07:32 PM Thread Starter
No engine work. Only thing close is SE heavy breather and SE slip on mufflers.
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #6 of 8 (permalink) Old 07-05-2014, 08:16 PM
What work did you do to the bike? What type of wiring work?
post #7 of 8 (permalink) Old 07-05-2014, 11:19 PM
FDR's RGC's Avatar
Have you done the primary chain adjustment. You use 1st gear run up to 30 and use the rear brake till it almost stalls without pulling in the clutch. Could be a loose primary chain slapping around.
post #8 of 8 (permalink) Old 07-06-2014, 12:13 PM Thread Starter
I put in a switch on the left side of the lower dash, put together a deutch plug, plugged that into the Y duetch connector I got from HD. It runs fans under the seat and behind the engine.
2018 Road Glide
ABS. Boom Audio
pauld is offline
Pretty loud clank and rattle on startup scooterh72 Engine Related 8 03-02-2017 11:52 AM
Very loud clank when shifting or getting on throttle or letting off throttle Callahan69 Engine Related 28 11-14-2016 02:09 PM
Trip and clank? palmpalm *General Road Glide Discussions/Pictures 8 07-02-2014 04:02 PM
Clutch in....... "CLANK"..? Plz Help! Scootin Tech Area 15 11-17-2013 03:27 PM
2011 RGU Engine "clank" sound... help!! roadog28 Troubleshooting for Road Glides 8 07-01-2011 10:19 PM
