Runs poorly after filling up with gas - Road Glide Forums
post #1 of 10 (permalink) Old 07-07-2014, 10:48 AM Thread Starter
I have a 98, EVO, bored and cammed, and a worn out carburetor that needs replaced. It seems to run OK until I get fuel. Then it runs poorly for 10 mins. Any ideas?
PAhumbug is offline
post #2 of 10 (permalink) Old 07-07-2014, 11:02 AM
If you don't have a fuel filter, I suggest you install one. Rebuilding your carb should be next on your list. Good luck.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #3 of 10 (permalink) Old 07-07-2014, 11:09 AM
PGR
PGR's Avatar
Try not filling it to the top.
Edit: That wasn't meant to be a smart a$$ remark. Sometimes the tank doesn't vent when you over fill it, and it creates a vacuum in the tank. This causes a lean condition, and the engine runs like crap for a while. My Panhead would do this if I topped it off. It had an aftermarket tank on it, and no Tillotson tube.
Ron..........................
PGR is offline
post #4 of 10 (permalink) Old 07-07-2014, 11:58 AM
crossbonesglide's Avatar
Thumbs up
I read your comment and didn't take it as being smart a$$. I'm with you on your line of thinking and wonder if the gas cap might be bad?
crossbonesglide is offline
post #5 of 10 (permalink) Old 07-07-2014, 01:17 PM
kouack's Avatar
+1 on the gas cap, when i use to have my softail i replaced both gas cap with low profile one, and of some reason my bike would stall,( high speed not at low speed in town) so i did coast down on the side of the road and ok what the f is going on? checking all the basic fire,air and gas, after i checked the basic the bike would start again and run like a charm for little while and stall again to realise the stupid gas cap would not vent.
kouack is online now
post #6 of 10 (permalink) Old 07-07-2014, 01:28 PM
usraptor's Avatar
I had the exact same problem with my 2000 Heritage. Check to see if your tank vent line goes to a charcoal canister inside the lower frame. Mine did (Stupid Calif EPA regs) and when I disconnected the vent line from the canister no more problems with it running bad after a fill up. Good luck.
2013 RGU, Vance and Hines Prop pipe and Fuel pak, SE AC, Wild One Chubby bars, Mean City Cycle Seat, Bright Ass tail light and LED turn signals, plus lots of chrome billet parts!
usraptor is offline
post #7 of 10 (permalink) Old 07-08-2014, 10:40 AM Thread Starter
How many hoses are supposed to come off the tank? Is there an overflow hose and a vent hose? I only have one. This bike HAS been severely molested so I always assume it's missing parts or installed improperly, which is usually the case.
PAhumbug is offline
post #8 of 10 (permalink) Old 07-08-2014, 11:00 AM
PGR
PGR's Avatar
Pull your seat and look at the rear of the console. There should be a rubber hose coming out from under the console.
PGR is offline
post #9 of 10 (permalink) Old 07-09-2014, 10:38 AM
The Charcoal canister is only installed on bikes that are sold new in California. That is why you never buy a used bike from CA.
post #10 of 10 (permalink) Old 07-09-2014, 05:34 PM
I would also check the vacuum lines from the petcock to the carb. Only if it is the original "CV" carb. If there is no vacuum line, check and make sure where the vacuum line connects to the carb that it is blocked and has a positive seal, if the original petcock was replaced with something like a "Pingle" petcock. Also clean and rebuild the carb. Pretty easy to do, but get a re-build kit for the carb for like $20.00. Remember Air, Spark, & fuel is all you need to get an internal combustion engine to run as long as the timing is set correctly.
2012Road GlideUltra-Vivid Black,Vance & Hines Two into One Pro Pipe,Screamin' Eagle Race Pro Tuner,Screamin' Eagle High Flow Air Filter,16" L.A. Choppers Apes,16" Klock Werks Windshield,Hogtunes Big Ultra RG Audio Upgrade Kit,"Tall Boy" Seat,Chrome Levers,Grips,TurnSignalVisors. Powdercoated Fork Lowers&Cowbells,Metzeler Marathon 888's,Gold Valve Cartridge Emulators,GloveCompartment, Saddlebag,Trunk and Lower Fairing Liners,Highway pegs, Legend Revo-A's,Hog Trough Cup Holders
kevinhd1690 is offline
Test runs after FuelMoto upgrades Mdwatson Intake and Exhaust 1 03-28-2015 08:18 PM
Filling King Tour Pak Backrest Holes 93-331-29psi Do-IT-Yourself 4 05-26-2014 11:36 AM
Filling Tour Pak Holes gfyoung3 Paint & Bodywork Section 3 02-15-2014 12:40 PM
Filling Holes on Tour-Pak from Antenna Mount hoser6868 *General Road Glide Discussions/Pictures 6 02-23-2012 11:21 PM
Filling hole for mirror. fosterp Controls & Handlebars 8 01-28-2012 11:56 AM
