Bad battery or something else ? - Road Glide Forums
post #1 of 14 (permalink) Old 07-18-2014, 08:32 PM Thread Starter
redbaron's Avatar
started up my bike today and my engine and battery light came on. the voltage showed 12 on my instrument cluster. As I rode about 10 miles the voltage dropped to 11 then 10, the bike however ran fine. got home turned the bike off then tried to restart the bike.....barely turned over - did not start. waited 2 hours tried again, almost started. I am thinking bad battery but just wondering if it could be something ( voltage regular etc.) else before I pick up a new one. bike and battery are 2 years old.
2012 Vivid Black, FM Ceramic 2-1-2 Header + 4" slash up mufflers Power Vision, PM Super Gas MERC A/C, 12" Windvest, CVO Solo Seat, XT Rokker & Hawgwire cs300 Amp, 10" Outlawz, CD Led's, Arlen Ness lowers, Ohlins S36E + progressive monotubes
redbaron is offline
post #2 of 14 (permalink) Old 07-18-2014, 08:35 PM
throttles&triggers's Avatar
The 2012's had a regulator recall. I'd check to see if yours was replaced.
throttles&triggers is offline
post #3 of 14 (permalink) Old 07-18-2014, 09:01 PM Thread Starter
redbaron's Avatar
mine was replaced after 25 miles...have about 10k on the bike now, hoping this VR is good.
redbaron is offline
post #4 of 14 (permalink) Old 07-18-2014, 09:09 PM
I have kept all my bikes on Battery Tenders over the years and never had to change out a battery, even after 6+ years on one. You could have a battery issue...should be simple enough to test.
post #5 of 14 (permalink) Old 07-18-2014, 09:21 PM
Triplej's Avatar
It sounds more like a charging issue than a battery issue and you were running off the battery voltage. That is why the constant drop in voltage as you rode.
If the bike was charging you most likely would not have seen such a drastic drop on the bikes voltage after it was running.
Check for DTCs and have the bikes charging system checked as well as having the battery load tested after it is fully charged and go from there.
Sometimes it's as simple as a loose/corroded cable.
Triplej is offline
post #6 of 14 (permalink) Old 07-18-2014, 11:25 PM
Your voltage regulator may have been changed already but it sounds like it needs to be changed again.
post #7 of 14 (permalink) Old 07-19-2014, 09:16 AM
JacktheBagger's Avatar
VR or stator , went thru this last year , and a battery to boot in the end
JtB
2011 Ultra
JacktheBagger is online now
post #8 of 14 (permalink) Old 07-19-2014, 09:54 AM
Classic symptoms of a stator problem. Thats what my bike did, it would start out at 12v or around there when cold but as I rode the bike and the stator warmed up the voltage would drop to around 10v. I am still running the original VR on my 08 and the stator was the only problem I had with the charging system.
Pull the derby cover if you smell a burnt wire smell than your stator is going bad.
I wouldn't ride the bike very far because the bike will only run so far on just the battery and if the battery is drained you will be looking for a tow.
post #9 of 14 (permalink) Old 07-19-2014, 11:09 AM Thread Starter
redbaron's Avatar
Thanks for all the info guys......charging the battery right now and I will test it once fully charged. I will pull the derby cover off next - to check for the "smell" and go from there.
redbaron is offline
post #10 of 14 (permalink) Old 07-19-2014, 11:25 AM
Don't go by the gauge on the dash. Mine reads 15 1/2 sometimes 14 sometimes. When it read 15 1/2 I got nervous and read the battery with a multimeter and it was 14.1 running.
V&H Exhaust//Stage 1 intake//6k HIDS//12" KW Flare//12" Buky Assaults// Arc Audio 125.2// Alpine 5 1/4 components// Alpine head unit//color matched gauges//chrome this chrome that
FLTRick is offline
bad VR or bad stator? Gonekat Troubleshooting for Road Glides 14 11-05-2014 06:29 PM
Well, found something else that can vibrate loose! Govdog76 *General Road Glide Discussions/Pictures 7 05-13-2014 11:33 AM
Install was not that bad..Alpine and J&M not a bad team Sixnine68 Audio 10 01-31-2014 05:28 PM
Has anyone else seen this bad ass RG DemonCity *General Road Glide Discussions/Pictures 2 06-08-2011 03:02 PM
