Red Key Light On Speedometer - Road Glide Forums
post #1 of 13 (permalink) Old 07-24-2014, 02:10 PM Thread Starter
Exclamation Red Key Light On Speedometer
While installing a load equalizer, I accidentally unplugged the security system wire and the all hell broke loose with the siren going off. I got the alarm to shutoff by turning the ignition knob on wnd off. However, now the red key icon stays lit all the time, even when I am riding it. Is there a way to fix this? If someone could message me or post a reply, it would be greatly appreciated. Thanks!
Luis FLTRX-13 is offline
post #2 of 13 (permalink) Old 07-24-2014, 02:37 PM
JacktheBagger's Avatar
sounds like you need to reset the TSSM , aint got it in front of me but it involves cycling the ignition switch and turn signals , someone may know or I'm shure google knows how
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 13 (permalink) Old 07-25-2014, 11:52 AM Thread Starter
Can't find how to reset it, anyone know?
post #4 of 13 (permalink) Old 07-25-2014, 12:15 PM
93-331-29psi's Avatar
if your security light stays on for a prolonged period of time, if you have changed your battery or disconnected your battery when fitting components such as LED turns & if you have fitted LED turns without a load equalizer, you will need to reprogram your OEM Module.
text in red below step procedure is confirmation of action, always wait for confirmation before hitting the next step:
step # 1. move handle bar kill switch to off position
step # 2. turn your ignition key: on-off, on-off then on
step # 3. hit the left turn signal twice.
your turn signals and indicator light will flash 1 - 3 flashes
step # 4. hit the right turn signal once.
turn signals and indicator light will flash once.
step # 5. hit the right turn signal once.
turn and indicator signals will flash twice.
step # 6. hit right turn signal once.
turn and indicator signals will flash three times.
step # 7. hit left turn signal once.
turn and indicator signals flash to indicate error code
step # 8. to now clear codes, hit left turn signal and hold down for 6 seconds until confirmation.
turn and indicator signals flash twice.
step # 9. turn the ign switch to off
93-331-29psi is offline
post #5 of 13 (permalink) Old 07-25-2014, 01:13 PM
CNMTurner's Avatar
And you shake it all about,
You do the hokey pokey
and you turn yourself around
That what it's all about.
Sorry folks.. Just one of those days..
2010 FLTRX - Stage 4 SE 113 - MVA Heads, 10.5:1, SE266E cams, 58mm TB, 5.3 gr/s injectors, Polished and plated motor and trans and a few chrome extras. Fullsac DX Header and Freedom Performance Classic 4" Slip-ons. Titan II 6.5 speakers with RF PBR300x2, Monroe Airshocks
1996 Tail dragin' Fatboy
CNMTurner is offline
post #6 of 13 (permalink) Old 07-25-2014, 03:04 PM
RoadGlideGary's Avatar
Smile
Exactly what I was thinking! LMAO!
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #7 of 13 (permalink) Old 07-26-2014, 11:18 PM Thread Starter
Thanks, that did the trick!
post #8 of 13 (permalink) Old 07-28-2014, 05:13 PM Thread Starter
Okay, I did the turn signal thing and all it did was display my alarm PIN on the odometer, does the fact that I have a Thundermaxx autotuner make a difference?
post #9 of 13 (permalink) Old 07-28-2014, 07:03 PM Thread Starter
So the red key icon is still on.
post #10 of 13 (permalink) Old 07-28-2014, 08:12 PM
Q-Hog's Avatar
The TMax can cause it to light up. That's one of the quirks of having a TMax. I have a TMax and it does the same for me. If you can, just ignore it as long as you know your turn signals and alarm is functioning properly and you have a good battery in your fob.
Q-Hog is offline
Right blinker does not work, red key is on in speedometer [email protected] Lighting 4 06-12-2018 10:46 AM
Red key light stays on jprider4life Engine Related 10 04-27-2014 09:40 PM
Red Key Light on Odometer. Q-Hog Troubleshooting for Road Glides 25 12-30-2012 02:28 PM
Red Key Light in Speedo Bar Regular *General Road Glide Discussions/Pictures 5 05-25-2012 10:02 AM
Red key light stays on choppermike Troubleshooting for Road Glides 7 03-02-2012 08:29 AM
