Dr Ruth - Road Glide Forums
post #1 of 3 (permalink) Old 07-27-2014, 04:56 PM Thread Starter
Dr Ruth
Fellow Gliders,
I have noise as I lean into a left only turn. No noise in a right turn. Noise is more pronounced the faster I go. It's a gur, super fast tap, buzz kind of sound. Something like a feathered tire could sound like, but tires look fine. Neck bearing adjustment, wheel bearings, or maybe brakes ??
Look forward to hearing from you Dr Ruth.
Signed
"Don't like the noise"
Only a Biker knows why a dog hangs his head out the window.
monkeybutt is offline
post #2 of 3 (permalink) Old 07-27-2014, 05:36 PM
faststan's Avatar
I would pull the wheel and check the bearings.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 3 (permalink) Old 07-27-2014, 06:26 PM
sj01fltri's Avatar
My 12 RG started doing it at about 10,000 miles put on a new rear wheel and tire with new bearings at 15,000 and noise went away,now at 17,000 its back,only hear it when cornering at 50 and above,figure it must be the tires,using the factory Dunlops both times.
sj01fltri is offline
Dr V twin plumcrazeman *General Road Glide Discussions/Pictures 5 08-09-2012 11:26 AM
Dr V-twin spender9 *General Road Glide Discussions/Pictures 14 01-25-2011 04:08 PM
Dr. V-Twin & Hell's Foundry SHOUT-OUT TracyB *General Road Glide Discussions/Pictures 3 12-30-2010 06:59 PM
Dr V-Twin Service DonL Equipment-RG 2 06-28-2010 10:00 PM
