Braking Issue - Road Glide Forums
post #1 of 12 (permalink) Old 08-02-2014, 09:17 PM Thread Starter
Q-Hog's Avatar
Braking Issue
Problem:
I vacuum bled the front brake line from the caliper. Rides good then loses brake pressure on the lever after several squeezes. Pressure resumes after I squeeze again but jerk slight to the right when squeezed/braking.
I took it to HD and they bled it using the same method because I have a Tmax tuner. The HD ABS computer won't work with the Tmax ECM. So they bled it the conventional way with a vaccum. Left with it working good, a mile later, same thing happened after several squeezes of the brake lever, Lost pressure and slight jerk to the right when squeezed.
Parts:
Single side PM 6 front piston caliper, Russell brake line (for RG with ABS) from ABS box to front caliber, stock front master cylinder and SMT 1 piece rotor.
I Think the problem is with the caliper or master cylinder. I'm at wits end. Any and all help will be appreciated. Thx.
Q-Hog is offline
post #2 of 12 (permalink) Old 08-02-2014, 09:37 PM
I would check for a warped roter first, if its good after one pull then something is making the pads retract to far back .
Eagle is offline
post #3 of 12 (permalink) Old 08-02-2014, 09:41 PM Thread Starter
Q-Hog's Avatar
Braking Issue
When the break works properly it doesn't vibrate or jerks. just later on it starts losing pressure and slightly jerk to the right. How do you check for a warp rotor? Thx
Q-Hog is offline
post #4 of 12 (permalink) Old 08-02-2014, 09:42 PM
I would see if you can eliminate the tuner so it can be bled the "proper" way needed for ABS. I don't have ABS so I don't know the procedure to bleed them but I would try that before you condemn the master cylinder or caliper. I do know on some vehicles (Chevy Silverados amount others) that the ABS needs to be activated by computer to properly bleed the brakes.
post #5 of 12 (permalink) Old 08-03-2014, 08:59 AM Thread Starter
Q-Hog's Avatar
I was thinking of doing that. Thx for the info.
Q-Hog is offline
post #6 of 12 (permalink) Old 08-03-2014, 02:37 PM
Bumping up for Q......... want to make SW4.
post #7 of 12 (permalink) Old 08-08-2014, 07:47 PM
93-331-29psi's Avatar
Braking Issue
Never mind I can't read
93-331-29psi is offline
post #8 of 12 (permalink) Old 08-08-2014, 08:08 PM
So are the results in yet? Curious if the new rotor solved the problem.
Drew
HogPro is offline
post #9 of 12 (permalink) Old 08-08-2014, 08:27 PM
Drew
Kinda curious myself
post #10 of 12 (permalink) Old 08-08-2014, 08:43 PM
mitchdm's Avatar
My .02 is the ecm needs to go back in the bike so the Boutique can properly change the fluid. Then if that resolves the issue drop the tmax back in. Good Luck. The abs is supposed to be cycled so the fluid can be properly flushed.
mitchdm is offline
Decreased braking power??? Johnzz1420 Wheels and Tires 32 10-05-2012 03:01 AM
front end chatter under braking? junk runner jr Suspensions 5 08-17-2012 03:19 PM
ABS kicks in under light braking cypress Troubleshooting for Road Glides 8 07-07-2012 07:28 PM
Transmission Braking and how any times vontoughguy *General Road Glide Discussions/Pictures 7 10-13-2011 09:40 AM
Motorcycles: Closest braking to the Wall DreamRider Videos 4 01-23-2011 11:22 AM
