Keep losing oil pressure gauge light? - Road Glide Forums
post #1 of 8 (permalink) Old 08-04-2014, 09:18 AM Thread Starter
cobra206's Avatar
I recently noticed that the light on my oil pressure gauge went out. I am using the led upgrades from superbrightleds.com. I pulled the fairing replaced the led, checked that it was working (it did), so I buttoned up the fairing, rolled the bike out of the garage, turned her on (led still good) then started the engine and boom the light goes out again. No other problems all other gauges are lit up properly. I had to order more LEDs so I have to wait before attempting another swap.
Do I have a short some where? Any ideas where I should start looking?
Sent from Motorcycle.com App
cobra206 is offline
post #2 of 8 (permalink) Old 08-04-2014, 09:58 AM
Cobra
I had a similar problem with my amp gauge itself, turned out to be a loose contact in
the actual 'connector', had to ensure the 'male clip' was pushed into the plastic connector all the way. Might be worth checking on the bulb connector. Good luck
mpears53 is offline
post #3 of 8 (permalink) Old 08-04-2014, 10:50 AM
I had the problem with my fuel gauge. The problem was right in the bulb socket. The socket is all molded so there is no way to repair it, I got a new socket at the local HD dealer, it was only a couple of dollars.
post #4 of 8 (permalink) Old 08-04-2014, 01:17 PM Thread Starter
cobra206's Avatar
Once my LEDs get here ill check the connector.
cobra206 is offline
post #5 of 8 (permalink) Old 08-04-2014, 05:34 PM
hoosierboarder's Avatar
Had the same problem with mine.just used zip ties through the bracket & over the back of the socket. No problems since.
'09 Road Glide
hoosierboarder is offline
post #6 of 8 (permalink) Old 08-04-2014, 06:00 PM
Shrug's Avatar
+1 zip ties.
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
post #7 of 8 (permalink) Old 08-04-2014, 06:23 PM
Bluchevypick's Avatar
I had the same issue to find the lead had come unsoldered from the bulb itself. I took the bulb apart and fixed it
Bluchevypick is offline
post #8 of 8 (permalink) Old 08-05-2014, 03:56 PM
Stick_FSMC's Avatar
I've been having the same issue with the Air Temp gauge.
I took it apart and fixed the wires on the LED "bulb", tested fine with the fairing off, but the first ride out after the repair, it starting flickering on/off again. Now it's off all the time. At least that's a non-essential gauge and once the flickering stopped, it's not so annoying at night. Thanks for the suggestions about the connector and zip ties. I'll check the connector when I take the clamshell apart next time.
Stick
USAF 1980-84
Stick_FSMC is offline
Tire pressure gauge & tire depth gauge cobra206 Miscellaneous for Sale 1 12-04-2016 11:37 AM
Oil Pressure gauge Too Short Troubleshooting for Road Glides 4 04-03-2012 06:30 AM
use of a oil pressure gauge for air psi??? bigeyed76 Equipment-RG 9 03-11-2012 11:31 PM
oil pressure gauge Jerry W. General Off-Topic Discussions 1 08-30-2011 04:36 PM
Oil pressure gauge 2010fltrx Troubleshooting for Road Glides 1 08-16-2010 04:09 PM
