2011 rg ultra w abs frt brake spongy - Road Glide Forums
post #1 of 12 (permalink) Old 08-07-2014, 08:55 PM Thread Starter
burnah's Avatar
in short frt brakes felt spongy last week. pads were worn so replaced without opening the system. fluid level looks good and still feel spongy. brought to a (non dealer shop ex hd tech with own shop over 30 years) bled system 3 times each time it would pump up until a short ride the go spongy again. hes thinkin electrical, im bumming as shark week starts in 3 days I have the week off and i may be without a bike! any ideas?
"I still dont know what Im goin for...But Im gonna go for it for sure!!!"
burnah is offline
post #2 of 12 (permalink) Old 08-08-2014, 12:38 AM
Use the back brake. Allow ample following distance and go to shark week. Everyone"s comfort level is different though.
roadglidetouring is offline
post #3 of 12 (permalink) Old 08-08-2014, 01:09 AM
If you "pump" the brake lever does it get better?
post #4 of 12 (permalink) Old 08-08-2014, 05:06 AM Thread Starter
burnah's Avatar
as long as i pump the lever once or twice the brakes do work
burnah is offline
post #5 of 12 (permalink) Old 08-08-2014, 05:27 AM
mitchdm's Avatar
You may want to consider going to the Boutique and having them flush it on the digital tech. They can cycle the ABS to completely eliminate any air. I had this done on my 12 and they charged me 30 minutes.
mitchdm is offline
post #6 of 12 (permalink) Old 08-08-2014, 08:17 AM
+1.I mentioned in another thread similar to this, there are some vehicles (Chevy Silverados among other's) that need to have the ABS system activated by computer in order to properly bleed the brakes. I would bring to the dealer so they can do it.
post #7 of 12 (permalink) Old 08-08-2014, 10:50 AM
Take it to the dealer and let them bleed it with the digital tech since it is an ABS bike. This will cost you but brakes are probably a relatively important part of the bike to having working properly.
To me, brakes and tires are the two most important pieces of equipment on the bike.
Drew
HogPro is offline
post #8 of 12 (permalink) Old 08-08-2014, 11:38 AM Thread Starter
burnah's Avatar
thanx for the input
burnah is offline
post #9 of 12 (permalink) Old 08-15-2014, 11:22 AM Thread Starter
burnah's Avatar
turned out to be
warped frt rotors. had the digital tech done and still did it. they said everytime the rotor came around it pushed the caliper piston back so id have to pump the lever for it to reach the rotor. thought I would have felt a pulsation be never really did. hope this saves one of you money if you ever come across this problem.
burnah is offline
post #10 of 12 (permalink) Old 08-15-2014, 11:47 AM
Must be warped pretty bad for it to feel like that. Maybe a wheel bearing is starting to go bad and the wheel is moving from left to right? I don't see rotors being warped without a pulsation in the lever.
HogPro is offline
2011 RGU with ABS - Brake Fluid Change Minivend Do-IT-Yourself 11 08-15-2015 06:16 PM
Radial frt and factory bias rear HDrider1 Wheels and Tires 3 02-02-2015 10:55 PM
'10 fltrx rear brakes spongy recently? kyle31490 *General Road Glide Discussions/Pictures 19 08-30-2014 08:45 PM
frt tire has cuts kentucky cowboy Wheels and Tires 7 03-16-2013 11:21 PM
2011 RG, frt end wobble 40-45 mph, bad ECU sheriff61 Road Glide Specific Discussions 19 12-13-2011 03:19 PM
