Fairing attachment screw stripped out. - Road Glide Forums
post #1 of 12 (permalink) Old 08-08-2014, 11:52 PM Thread Starter
Does anybody have a suggestion other than a larger size screws to attach the inner and outer fairing. I have stripped mine out.
Straitline is offline
post #2 of 12 (permalink) Old 08-09-2014, 12:23 AM
FrankieB's Avatar
Use JB weld, i prefer the stick style for this but the putty version will work. Mix it up and i use a match stick to jab it all the way full. The drill it for the screw size.
06 RK
11 RGU
FrankieB is offline
post #3 of 12 (permalink) Old 08-09-2014, 08:35 AM
1st Sgt's Avatar
JB Weld here too. I used the putty type, filled the screw hole then before it set I greased the screw, line it up and put it in. Let the putty dry with the screw in it like that and it created threads. Haven't had a problem with that approach yet and it's held up for over 30k miles.
1st Sgt is offline
post #4 of 12 (permalink) Old 08-09-2014, 09:24 AM
ZachB's Avatar
Small piece of zip tie in one of mine. Happened over 7K miles ago. Just did a 5800 mile round trip and it never let loose. I May do a more permanent solution next time I have the fairing off.
2015 RGS 103" Denim Black, Drago's 2:1, SE Heavy Breather, SEPST, Tuned. That will do for now.
ZachB is offline
post #5 of 12 (permalink) Old 08-09-2014, 09:41 AM
There a lots of threads on this subject so if you do a search you will find all sorts of suggestions.
I do the JB weld thing too, spray some cooking oil on the screw and let it dry (the cooking oil is a release agent) then mix up the JB weld and stuff it in the hole in the fairing and then take the screw and SCREW it into the soft putty, let the JB weld set up and unscrew the screw. The screw threads are already in the repair so there is no need to drill or tap.
The fairing screws are only suppose to be tightened to 9 inch lbs so it doesn't take much to strip the hole.
post #6 of 12 (permalink) Old 08-09-2014, 09:58 AM
jimmyray11349's Avatar
Go to Home Depot. Get Mr. Grip. It is on a yellow card and is a piece of tin that u cut into strips. I put it in all 6 holes. Works great. $2 fix.
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #7 of 12 (permalink) Old 08-09-2014, 06:31 PM
RoadGlideRider's Avatar
I have cut small strips of Weed Wacker line. I placed one or two, dependent on how large the hole, and threaded the screw. This is not a permanate fix. But it didn't cost me anything but time.
RoadGlideRider is offline
post #8 of 12 (permalink) Old 08-09-2014, 08:44 PM
hoosierboarder's Avatar
Saw these in another thread & they work great. Get em at home depot. You can even use & reuse without problem. Cut to size. About $1.50 for the pack.
'09 Road Glide
hoosierboarder is offline
post #9 of 12 (permalink) Old 08-09-2014, 09:40 PM
OK Iím a little off subject here but it seems you have already got some good ideas here. The question is why did the screws strip out?
I pulled the fairing off my new 2013 last winter and when I went to put it back together it seemed to be putting a lot of pressure on the screws to suck and hold the inner and outer fairings together. I pulled the headlight assembly out and put the outer fairing back on without having to put any tension on the screws at all. All the factory wiring was getting in the way behind the headlights. After re-routing some of the wiring to free up space behind the headlights the fairings came together with the screws finger tight. If I hadnít moved the wiring I would probably have stripped out my fairing.
NightHawk45 is offline
post #10 of 12 (permalink) Old 08-10-2014, 11:54 AM
I agree.
I alway pinch the inner and outer fairing together with my fingers and just lightly seat the screws. NEVER try to pull the fairing together with the screws.
Also making sure the side fins are lapped right is critical.
NEVER use a electric/air screwdriver on the fairing screws alway tighten the screws by hand.
Stripped Inner Fairing Screw Hole the88virgnian Do-IT-Yourself 8 08-25-2016 09:44 AM
Outer Fairing screw hole stripped motosig102 Paint & Bodywork Section 37 08-02-2016 11:47 PM
Stripped Fairing Screw Hole EasternSP Paint & Bodywork Section 10 09-13-2012 11:40 PM
WTB 2007 Passenger sissybar/backrest and attachment brackets....??? Johnzz1420 Wanted! (Buy or Trade) 1 07-05-2012 06:17 PM
Stripped screw METIME Troubleshooting for Road Glides 13 10-24-2010 05:36 AM
