rough idle - Road Glide Forums
post #1 of 4 (permalink) Old 03-26-2012, 04:03 PM Thread Starter
rough idle
was wondering if anyone else has had this problem i have a 08 that since i got it i always thought it ran rough at idle if you give it a little gas it smooths right out but other wise it shakes you up i even changed the pipes and put a vance & hinges fuel comand on it and hasn;t changed abit let me know what you think
todd choops is offline
post #2 of 4 (permalink) Old 03-26-2012, 09:51 PM
What do you consider a rough idle, is the engine ignition not firing on both cylinders? The 08 I have shakes like a nun in a whore house and it runs great, basically this is the nature of the beast and that the true HD signature IMO. If it sounds like it is running on one cylinder when the engine is HOT and you are stopped then it is the heat management system, the heat management system can be turned on or off depending on the riders preference.
post #3 of 4 (permalink) Old 03-27-2012, 12:18 AM
Shark daddy's Avatar
Mine shook so bad I thought the tour pak was going to fall off and found I had a bad motor mount. Had a new mount installed and now much better, but it still shakes, but not as bad.
"Don't Cheat yourself, Treat yourself"
2015 Superior Blue RG Special
Shark daddy is offline
post #4 of 4 (permalink) Old 03-27-2012, 08:36 AM
CHAINSAW's Avatar
Had a friend that his was shakin real bad. It was the top stabilizer bar thing on the top of the front cylinder that was broke.
Such is the rule of honor.
CHAINSAW is offline
2016 road glide rough idle Yasso General Off-Topic Discussions 12 08-28-2018 07:24 AM
Front suspension 'rough' mpears53 Suspensions 13 08-01-2017 06:37 AM
Rich & Rough Idle gazrnr Troubleshooting for Road Glides 0 11-12-2016 07:35 AM
Rough idle, seems hot Lucky Engine Related 4 07-28-2015 01:09 PM
Fltruse runs rough smitty *General Road Glide Discussions/Pictures 5 08-12-2011 09:16 PM
