Crank no start, crank start - Road Glide Forums
post #1 of 11 (permalink) Old 08-10-2014, 09:07 PM Thread Starter
Sam07's Avatar
http://youtu.be/7C0rV8wfOLo
Like the title says. I started noticing my 2013 RGC with 13k doing the above. The battery is fully charged and always starts on the second try. The dealer says its normal for the bike to crank up to 8 times before starting but the bike has never done this till now. The warranty is up at the end of the month so any thoughts? I'll be heading back to the dealer this week.
2013 RGC
Sam07 is offline
post #2 of 11 (permalink) Old 08-10-2014, 09:47 PM
Do you have any type of tuner on the bike? Its hard to hear but it sounded like it was popping through the A/C a few times?
post #3 of 11 (permalink) Old 08-11-2014, 08:01 AM Thread Starter
Sam07's Avatar
Yes, a screaming eagle tuner was added along with 255 cams, thunderheader, SE intake and SE plugs after the bike broke in at 1000 miles. No engine mods since then and shes been running great. The battery was tested and is holding 395 cca. I checked the plugs and made sure the spark plug wires are tight.
This morning, she started perfectly. Less than 2 strokes and she fired right up.
.... gremlins!
2013 RGC
Sam07 is offline
post #4 of 11 (permalink) Old 08-11-2014, 08:54 AM
RGKen's Avatar
My 2010 did the same thing. Had my battery tested also and checked out just fine. Had it tested again and it actually had a bad cell. Put a new battery in and no more problem. May not be your issue but that is what fixed mine.
2018 FLTRXS
RGKen is offline
post #5 of 11 (permalink) Old 08-11-2014, 11:10 AM
TLWiz's Avatar
Mine cranks a bit more to start cold than it used to (but just a bit) - I suspect the battery's age might be the factor.
TLWiz is offline
post #6 of 11 (permalink) Old 05-14-2018, 02:00 PM
RuffRider's Avatar
I have a 2012 street glide with about the same set up doing the exact same thing. Did you ever figure out the true issue?
RuffRider is offline
post #7 of 11 (permalink) Old 05-14-2018, 03:13 PM
geo8866's Avatar
Have you changed the Spark plugs?
geo8866 is offline
post #8 of 11 (permalink) Old 05-14-2018, 05:13 PM
Thermodyne's Avatar
What happens if you just let it flip over a couple of turns, then hit the starter again? As opposed to letting it turn though six or seven times before trying a second time.
It gets a little extra fuel each time you hit the starter button. And some maps are a little stingy with that.
Thermodyne is offline
post #9 of 11 (permalink) Old 05-15-2018, 06:59 AM
RuffRider's Avatar
No codes, Changed plugs, check plug wires, Mapping was checked and is right where it was dyno'd to. It's like it's not getting spark and loads up with fuel. If I stop cranking then hit it again it starts normal, sometimes back firing a little because it loaded up with fuel. It's just like in the video Sam posted and started out once in a great while but now is more often than not. Was hoping he would chime in if he ever resolved the issue. The dealer changed the crank position sensor, said it was cutting out intermittently (horse crap) and $150 later it's still doing it. Their now going to Harley tech.
post #10 of 11 (permalink) Old 05-15-2018, 07:51 AM
Stoic Joker's Avatar
My 10 is a bit persnickety about starting when it's hot out (regardless of her temperature), but always pops right off on the second try. But I had also been following the dealer instructions given when I picked her up to always wait for the engine and alarm lights to go off before hitting the starter. Which is 2 or 3 seconds after the pump stops. And adding more fuel to the start had no effect.
Recently - curious puck that I am - I decided to try going for the start right after the pump shut off, and damn if she don't start on the first try damn near every time now.
I've never been a fan of grinding on the starter, 2-3 turns tops and let go.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is offline
2017 RGS will crank over, but won't start cwcorris Engine Related 5 01-05-2018 11:14 AM
big crank or mega crank battery Onthehunt49 General Off-Topic Discussions 7 04-10-2016 06:27 PM
Stock crank vs. S&S crank HDBAGR Engine Related 11 05-23-2015 04:21 PM
No Start MagicIHM Troubleshooting for Road Glides 7 06-17-2012 04:57 AM
Strong electro field = no start yzernie *General Road Glide Discussions/Pictures 11 09-20-2011 02:43 PM
