Broken outer fairing screw post? - Road Glide Forums
post #1 of 8 (permalink) Old 08-11-2014, 08:46 PM Thread Starter
Driftah's Avatar
Hello all,
I wasn't sure what to call the part but I've broken off one the threaded posts where the screws that hold the inner and out fairing together seats. Specifically the lower right screw. I've got the piece that broke off and I'm wondering if there is some way of re-attaching it; some sort of super glue or joining compound that might work? I hoping I don't have to get another fairing for such a small issue...
Has anyone re-attached one of these posts or have a work around?
Any advice would be greatly appreciated.
Regards,
-D
p.s. I've also a small crack where the turn signal attaches. Any suggestions for that?
Driftah is offline
post #2 of 8 (permalink) Old 08-11-2014, 10:22 PM
Are you talking about the upper fairing support bracket that attaches to the crash bar or is the problem in the threaded stud in the turn signal?? Some pics of the bracket and the crack in the fairing would help.
post #3 of 8 (permalink) Old 08-11-2014, 10:31 PM
mechanical1's Avatar
Horrible design isn't it. You can epoxy it back together. You can put the screw in and use it to hold them together. Apply "splints" along side the screw post with epoxy. The splints will make it a stronger weld instead of just butt welding it on with epoxy.
mechanical1 is offline
post #4 of 8 (permalink) Old 08-12-2014, 09:39 AM
TLWiz's Avatar
JB Weld is good stuff, hopefully you can glob enough on to make this stress point sturdy again. http://www.jbweld.com/
TLWiz is offline
post #5 of 8 (permalink) Old 08-12-2014, 10:09 AM
bucketlisthd's Avatar
JB Weld a patch on the inside of the fairing over the turn signal crack.
Bed buttresses in JB Weld around screw post.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #6 of 8 (permalink) Old 08-12-2014, 10:09 AM
Dawiz50's Avatar
What he said ^ (mechanical1)...I have used Devcon Epoxy too...I like the '5 minute cure' type...butt weld it back on 1st...let it dry...then take your time and just build it up in layers to add extra 'bulk' to the mount. Let it dry at least 24 hours...and don't over tighten the screw...fixed!
1998 FXSTC Softail Custom (Heinz 57)
2000 Buell X-1 Lightning & 2006 Buell XB-12X Ully
2005 FLTR-I Road Glide
Dawiz50 is offline
post #7 of 8 (permalink) Old 08-12-2014, 11:00 AM
Sam07's Avatar
check out the plastic weld kits at harbor freight if epoxy or jb weld doesn't work. I've fixed a bunch of ATV and dirt bike plastic fenders with the kit. Plus i give you an excuse to play with FIRE! It basically melts the plastic together again.
2013 RGC
Sam07 is offline
post #8 of 8 (permalink) Old 08-12-2014, 11:36 AM Thread Starter
Driftah's Avatar
Thanks all!! You don't know how happy you've made me. The suggestions make sense. I'll try the JB Weld route and build up the area around the break (once dried) with some epoxy to strengthen --I might as well strengthen the others while the fairing is off .
It is a rather strange design. I don't think it would have cost much more to beef up those posts and maybe add an metal threaded insert. Although I don't know how much extra stress that would add to the fairing (I mean that luckily just the post broke. If it had been more sturdy could it have resulted in a cracks in the fairing at the anchoring point?). I'm no materials/structural engineer. I'm very glad, however, to have been given a solution that doesn't result in purchasing a new fairing! Thanks again Fellowship of the Shark Noses!!! Your knowledge and wisdom are very much appreciated!!!
Ride safe out there and best regards,
-D
Driftah is offline
Cross threaded screw on Outer Fairing-Advise? geo8866 Do-IT-Yourself 16 10-01-2018 07:16 AM
Outer Fairing screw hole stripped motosig102 Paint & Bodywork Section 37 08-02-2016 11:47 PM
Outer Fairing Screw Mount Issue Bleachey Do-IT-Yourself 12 07-10-2016 07:31 PM
Fix a broken tab on inner fairing? Lunchboxx Do-IT-Yourself 15 07-09-2016 04:42 PM
Middle fairing screw will not tighten?? Marco V Troubleshooting for Road Glides 5 03-23-2012 02:37 AM
