Battery - Check Engine Replicated 3 times - Road Glide Forums
post #1 of 15 (permalink) Old 08-14-2014, 08:48 PM Thread Starter
Paul's Road Glide's Avatar
Ok guys, need your input.
In three occasions starting yesterday morning and twice today in the evening....
Bike turns on fine but after a few minutes of rolling, my check engine light and battery light come on. I check the volt meter on the dash as I'm riding at it reads something like 11 give or take. After 15-20 minutes in each of the three occurences the volt meter then goes back to normal around 13.5 or so and the lights turn off.
I currently just bought a brand new battery. Only about 1 month old
VR was replaced about 25K miles ago
I pulled the derby inspection cover and looked for that infamous burnt wire smell from the stator but I guess it kinda smells like it (scratching head) but then again is it just the smell of hot synthetic oil. I dunno.
I guess where should I start?
Right now battery is charging on a tender and will then read off that.
Paul's Road Glide is offline
post #2 of 15 (permalink) Old 08-14-2014, 10:20 PM
JacktheBagger's Avatar
sounds like the stator , when mine went out , the voltage dropped to under 12 momentarily twice that I know of .. My battery died a couple weeks later
JtB
2011 Ultra
JacktheBagger is online now
post #3 of 15 (permalink) Old 08-14-2014, 11:20 PM
Gray Beard
lundboy1's Avatar
I'd say start simple with connectors pinched wires corrosion etc. then have the vr checked, final measure is stator
" wishin' my knees were in the breeze!!!"
lundboy1 is offline
post #4 of 15 (permalink) Old 08-15-2014, 10:06 AM Thread Starter
going to be doing the serious diagnostics this evening. I needed to let the battery charge overnight so I can test accurately.
I guess I don't care what it is, I just want to fix the right part the first time.
post #5 of 15 (permalink) Old 08-15-2014, 12:14 PM Thread Starter
Does anyone have the link or now the post that someone made on here about what procedures to check the charging system?
I found yesterday but now can't seem to find it.
Thanks.
post #6 of 15 (permalink) Old 08-15-2014, 06:18 PM
Thanks.
http://blog.jpcycles.com/step-by-ste...arging-system/
this should do ya along with specs of the 2010 system.
post #7 of 15 (permalink) Old 08-15-2014, 09:49 PM Thread Starter
Ok this is what I have done and found. thanks for the specs that helped a lot.
charged battery and is good at 12.8
unplugged stator and checked all three connections in the 4 phase mode. they checked out to specs above. that means stator and rotor are good.
also used a light meter and grounded it properly, turned bike on and check terminals at stator. light never came one. notes indicate that is a good thing.
My assumption is the VR is gone bad, but I couldn't find notes on how to check the VR. (nevermind. I see notes on JP cycles website).
Did I miss anything?
post #8 of 15 (permalink) Old 08-15-2014, 11:33 PM
Had the same thing which started to happen more and more frequently. All tested fine. Took it to the dealer under warranty and the stator and voltage regulator were replaced. The plug between the two had some burnt points in it. It's been fine the last 4000 miles.
HogPro is offline
post #9 of 15 (permalink) Old 08-16-2014, 08:40 AM
The VR can be very temperamental when going bad.
post #10 of 15 (permalink) Old 08-19-2014, 03:13 PM
My bike is currently doing the same thing. Did it end up to be the VR? I guess I'll be running tests too. I'm right at 10k, so my primary oil is due anyway.
NHFLTRX is offline
Check Engine & Battery Lights?? George W Troubleshooting for Road Glides 3 08-11-2016 02:35 AM
Check Engine Light and Battery Light following Jackpot 2-1-2 install PearlBlueUltra Troubleshooting for Road Glides 9 06-15-2014 04:59 PM
check engine and battery light drmudd Troubleshooting for Road Glides 11 04-20-2013 02:08 PM
engine stalls and also idle jumps to 2K at times Ahh-Ho RRMC Troubleshooting for Road Glides 12 01-04-2013 02:28 PM
