ECM plug wont lock - Road Glide Forums
post #1 of 4 (permalink) Old 08-17-2014, 08:48 PM Thread Starter
hoosierboarder's Avatar
ECM plug wont lock
I had a P1511 code yesterday. Found moisture in the ECM plug where it connects to the throttle body. Got the code cleared & bike ran fine. When I got home, I took the plug off to clean it & put some dielectric grease in. Now the plug won't lock. No pins bent, nothing seems to be interfering, as I can push the plug completely on. the tab is not broken, but won't lock. It doesn't pull off real easy but does pull off. Any suggestions?
'09 Road Glide
hoosierboarder is offline
post #2 of 4 (permalink) Old 08-17-2014, 10:00 PM
RoadGlideGary's Avatar
Unless there is something interfering (pin bent or mis-aligned) it should seat fine. Pull apart and check pins and see if anything is stuck in either boot. Should snap and lock in place with solid feel.
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #3 of 4 (permalink) Old 08-17-2014, 10:53 PM
Maybe too much grease?? A LiL Dab, I'l Do 'Ya...
HeatWave is offline
post #4 of 4 (permalink) Old 08-18-2014, 02:14 PM Thread Starter
Found the problem. The locking tab on the TCA plug (don't know why I said ECM) where it connects to the induction module was cracked. $13 got me a new connector housing & we're back on the road.
'09 Road Glide
SE Phat Plug Wires or OEM Plug Wires wevsspot *General Road Glide Discussions/Pictures 31 07-07-2017 11:17 AM
Tour Pack Lock W/Flat Key Lock. Bill-99RG *General Road Glide Discussions/Pictures 3 01-15-2015 02:16 AM
Who knows what pin in ECM plug is for cruise milkman48 ECM/Fuel Management systems 1 03-31-2014 09:33 PM
changed bars now bike wont start NO4NBIKES Controls & Handlebars 4 01-02-2012 11:06 AM
wont start The instigator Road Glide Specific Discussions 8 03-24-2011 10:20 PM
