Misfire no codes - Road Glide Forums
post #1 of 19 (permalink) Old 09-11-2014, 11:06 PM Thread Starter
Misfire no codes
I'm having an intermittent "misfire" or "hiccup" that I can't figure out. I'll be riding down the road and the engine will just sort of cut out for a split second. Seems to happen more under light throttle. There are no codes so I'm a bit lost. Bike has ran fine up until recently 50k and I haven't changed anything. Took it to a dealer while on a trip, they checked fuel pressure and it was good but the bike wasn't acting up then so they couldn't find anything wrong. I've tried new plugs, no change
Things I might try:
Dialectic grease on the TB connector
Checking injector wires for continuity while wiggling them
Replacing 02 sensors?
Any ideas or suggestions? Thanks guys
2012 FLTRX
Sideways is offline
post #2 of 19 (permalink) Old 09-12-2014, 12:42 AM
torqu's Avatar
Have you checked the wires & plugs? I know it sounds to simple. For $6 I would go get some Champion 810 plugs and try that. I have read story's about motor build and guys trying to pin point the issues the motor was giving them just to find out it was the most simplest issue.
torqu is offline
post #3 of 19 (permalink) Old 09-12-2014, 02:27 AM
Gray Beard
lundboy1's Avatar
This is textbook troubleshooting right here. Lots of guys always start on the 4th or 5th thing down the line.
" wishin' my knees were in the breeze!!!"
lundboy1 is offline
post #4 of 19 (permalink) Old 09-12-2014, 07:07 AM Thread Starter
I changed the plugs but have not tested the plug wires. I'll try that after work, thanks
2012 FLTRX
Sideways is offline
post #5 of 19 (permalink) Old 09-12-2014, 08:05 AM
torqu's Avatar
No codes stored at all? I just worked on an 08 that was in limp mode and the cause for that one was the TB plug. Cleaned it up and used dialectric grease. Clear the 3 codes that were saved and hasn't had an issue yet. But your not showing any codes. Mmm
torqu is offline
post #6 of 19 (permalink) Old 09-12-2014, 09:17 AM Thread Starter
Yeah no codes
2012 FLTRX
Sideways is offline
post #7 of 19 (permalink) Old 09-12-2014, 09:51 AM
RoadGlideGary's Avatar
I'd check the plugs, wires and electrical connections one more time. Could be a bad plug with a chip or damage to the porcelain, or a connection that is not tight. A dose of dielectric grease to electrical connections won't hurt. Sometimes the smallest things are the biggest PIA!
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #8 of 19 (permalink) Old 09-12-2014, 10:43 AM
You can check the plug wires with a multimeter, if the wires have around 5.5+/- ohms of resistance they are good. There is also the coil plug under the fuel tank make sure it has a good connection and use some dielectric grease on it.
You could have a dirty injector did you try running a little injector cleaner in the fuel??
I wouldn't think it would be the O2 sensors but you can pull them out and clean them with some carb cleaner just to make sure.
post #9 of 19 (permalink) Old 09-12-2014, 10:58 AM Thread Starter
I tried injector cleaner but it didn't seem to make a difference. I'll start with plug wires and go down the list. Thanks guys
2012 FLTRX
Sideways is offline
post #10 of 19 (permalink) Old 09-15-2014, 10:25 PM Thread Starter
Checked for codes again today after the bike was really acting up, and got these:
P0118 ET sensor voltage high/open
P0374 CKP sensor sync error.
I suppose I'll just go ahead and replace these sensors and hope for the best.
2012 FLTRX
Sideways is offline
2005 misfire cloud Troubleshooting for Road Glides 15 05-05-2014 09:34 PM
Codes and more codes SmokeyJoe Troubleshooting for Road Glides 3 03-09-2014 01:56 PM
Help please stalls no codes creed Troubleshooting for Road Glides 5 07-22-2012 09:08 PM
Rear Cylinder misfire blkbusa Troubleshooting for Road Glides 10 02-14-2012 03:56 AM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 06:02 PM
