Bagger Bags Integrated LED Wiring - Road Glide Forums
post #1 of 4 (permalink) Old 09-26-2014, 11:43 AM Thread Starter
Bagger Bags Integrated LED Wiring - Solved
Hey Guys,
So i am wrapping up my install of the Bagger Bags 4 inch extended bags/fender with their integrated led lights. I am very close with the wiring and just need to add a circuit for each blinker (I think). With the below pic everything works except when i hit the blinker both start flashing. Any advice would be appreciated.
[IMG]
screen capture software[/IMG]
peteys101 is offline
post #2 of 4 (permalink) Old 09-26-2014, 08:24 PM
chilidogtampa's Avatar
Your diagram has the blinkers and brake tied together, you cant do that without a module or a complicated series of diodes/relays but basically thats what the module is. Anyway if you want to wire it as is with no module you need to choose either brake or turn for your bright filiment, the low filiment is your running light.
An inexpensive way to acheive stop/run/turn would be to use a trailer taillight adapter if you have room to hide it.
HTH..
chilidogtampa is offline
post #3 of 4 (permalink) Old 09-26-2014, 08:53 PM
Shark of the Month August 13
SIC_26's Avatar
You can also run the custom dynamics box for the plasma rods...... I just need to remember what it's called :facepalm:
SIC_26 is offline
post #4 of 4 (permalink) Old 10-02-2014, 02:00 PM Thread Starter
Got it - just needed a couple diodes and resistors to stop the blinker current from flowing back to the other side!
[IMG]
uploading images[/IMG]
Harley Key FOB with Integrated Key bykw2 Parts for Sale 0 07-25-2018 08:57 PM
Custom Dynamics, integrated run, turn, brake light bar Smarty Lighting 15 08-28-2016 09:29 AM
Just ordered Native Custom Bagger Air Ride and Extended bags GLYDDN11 *General Road Glide Discussions/Pictures 18 05-14-2013 05:06 AM
Question on Integrated IPod..... Bluefilhd Audio 21 10-08-2012 09:46 PM
2012 new Integrated Oil-cooler on 103 batman825 Road Glide Specific Discussions 7 07-31-2011 04:36 AM
