Oil blow by around new air filter - Road Glide Forums
post #1 of 14 (permalink) Old 09-30-2014, 09:57 AM Thread Starter
glidethru's Avatar
I recently installed the Burst series air cleaner kit on my "12" Ultra. I have noticed a few different times that oil is dripping out of the bottom onto the cam cover . When I run my hands down at he bottom of the air filter there is a lot of oil and grime. I had the bike tuned with a new SERT after I installed the new air filter kit and the bike runs fine. What can be done to prevent this or control so it does not keep making a mess after I have cleaned.
MAGNA FLOW "Top Guns
Wild Ones 12" Chubbys
glidethru is offline
post #2 of 14 (permalink) Old 09-30-2014, 10:33 AM
ERod62's Avatar
Lower your oil level. Running mine just below mid mark. About 3 qt of oil. Oil check every month.
Run a search some one build a oil trap.
ERod62 is offline
post #3 of 14 (permalink) Old 09-30-2014, 11:43 AM
+1^^^
I put in 3 1/2 qts of oil when doing a oil change which put the oil at the 1/2 way mark on the dipstick and I have no problems with oil in the air filter.
post #4 of 14 (permalink) Old 09-30-2014, 09:14 PM Thread Starter
glidethru's Avatar
Thanks I am planning an oil change this week,,,I will try your suggestions
post #5 of 14 (permalink) Old 09-30-2014, 09:57 PM
It is quite common and running a lil less oil does seem to be the fix
post #6 of 14 (permalink) Old 10-01-2014, 08:22 AM
Hullhorr's Avatar
I installed the outlaw racing breather bolts from DK Customs and did away with the breather tubes. Bike runs better and no more oil in the air cleaner.
2009 FLTR MOP
Hullhorr is offline
post #7 of 14 (permalink) Old 10-01-2014, 08:48 AM
Scoop's Avatar
A Kotex lite days pad on the inside lower edge of the cover will absorb that excess blow-by, just replace it every now and then. I'm not a proponent of "less oil" in an engine that is basically cooled with oil flow. IMHO keep the oil level at full, don't over-fill it and deal with a little drip.
Ride Safe, have fun, repeat,
John
2011 FLTRU Fullsac Sportpipe, SE Breather/air cleaner, SEPRT Smart-tune, Corbin, Madstad 13", Gold Top Fork Emulators & Springs & JRI B shocks. 2003 XLHS
Scoop is offline
post #8 of 14 (permalink) Old 10-01-2014, 10:59 AM
I installed a kit from DK Customs as well. Venting the oil thru a filter to the ground. Have yet to see an actual drip in my garage.
2012 Road Glide Ultra
79HP 103 TQ, tuned by Ed at The Dyno Difference.
tsigwing is offline
post #9 of 14 (permalink) Old 10-02-2014, 08:09 PM
9over's Avatar
Used to get the same thing. Now I keep it two or three dots below full and no more drip.
9over is offline
post #10 of 14 (permalink) Old 10-02-2014, 10:02 PM
HogWild's Avatar
If its an air filter that you spray to treat like a K&N, it will also drip oil if you've sprayed the filter to heavily. Also agree if the engine oil is overfull (at all) its coming out somewhere, usually through the air filter.
"No man is rich enough to buy back his past, so enjoy the moment"
HogWild is offline
Oil Blow by at Air Cleaner Highway Troubleshooting for Road Glides 39 11-05-2017 12:33 PM
K&N Filter vs.HD Oil Filter RRHartzler Fluids and Lubricants 49 10-22-2016 08:00 PM
oil mist blow by Marco Troubleshooting for Road Glides 20 11-07-2014 09:56 PM
oil smell & oil in air filter fat boy ultra Troubleshooting for Road Glides 6 04-11-2013 11:04 AM
Need Help! Selecting Oil, Oil Filter & Air Filter Big Red 103 Do-IT-Yourself 5 06-06-2011 12:38 PM
