Thundermax proublems ? - Road Glide Forums
post #1 of 5 (permalink) Old 10-03-2014, 11:49 AM Thread Starter
I have a 2012 road glide with a big sucker intake, rineheart 2-1, and a powercomander 5. I bought a thundermax, installed it, it worked fine for about 3 months. Then the speedometer started only working about 2/3 the time , so I got ahold of thundermax , they after a time of sending data to them replaced the emc. Got the new one installed it does the same thing. I talked to Chris at cyclesolutions who I bought it from, he said about 9 or 10 bikes out of a 100 have problems with thundermax . He told me to clean the fuses use dielectric grease. Put more dielectric grease on the Harley plug that installs into the emc all of this I have done. It still has the same problem. Keep in mind I put the Pc-5 back on and everything works fine. Please help
craig demel is offline
post #2 of 5 (permalink) Old 10-03-2014, 01:16 PM
Bluchevypick's Avatar
The best advise i can give you is to contact Thundermax once again. They have really good tech support and will get it resolved.
Bluchevypick is offline
post #3 of 5 (permalink) Old 10-03-2014, 01:30 PM
eme56's Avatar
I had the same thing happen last summer - 3 times in one week. Like you, I cleaned the ECM plug and fuses and added a little dielectric grease. I also cleaned and greased the plugs on the back of the speedometer and tach. It has not done it since. You might give that a try.
2005 FLTRI Black Cherry, 95" Big Bore, Thundermax w/Auto Tune, V&H Dresser Duals w/Klock Werks SS, Andrews 26 Cams, SE Stage 1 intake, SE OD/6 Speed, Wards FCS cooling fans, Krome Werks Stretch Heritage +2 bars, Progressive Monotubes, 444's, & Touring Link, Michelin Commander II's, 14.5" Madstad, Lowers with Classic Motorcycle Vents, detachable King Tour Pack, Daymakers
eme56 is offline
post #4 of 5 (permalink) Old 10-03-2014, 04:53 PM Thread Starter
thundermax problems
Thanks Hanground, Ill try the diec grease on the speedo plug &see what happens
post #5 of 5 (permalink) Old 10-04-2014, 11:18 AM
Did you set the speedometer calibration when you installed the T-Max tuner. There are different settings for the speedometer and the setting on your base map may be the incorrect setting.
Go to basic settings and click on speedometer and check.
Thundermax TBW MakeARunMike ECM/Fuel Management systems 15 06-01-2011 11:07 AM
Thundermax on a stock 2010 RGC pab ECM/Fuel Management systems 18 12-22-2010 05:25 AM
Thundermax impression Rowdy ECM/Fuel Management systems 9 11-23-2010 10:27 PM
thundermax TBW roadgliderick ECM/Fuel Management systems 0 11-23-2010 01:36 AM
Zipper Thundermax Ranger58 ECM/Fuel Management systems 12 11-19-2010 11:26 AM
