Bumpy Surface Caused Shut Down - Road Glide Forums
post #1 of 11 (permalink) Old 10-05-2014, 06:13 PM Thread Starter
RaiderV-VZ's Avatar
went out for a Sunday ride and after ridding over some railroad tracks the bike was not responding to the throttle. I had to stop and realized the bike had turned off. Still had power, cause it would crank over, but would not start. My fuel pump light does not come on anymore and I can't hear the start indicator. Any ideas before I take it to the shop.
2013 Ultra
2013 RGU Midnight Pearl
RaiderV-VZ is offline
post #2 of 11 (permalink) Old 10-05-2014, 06:33 PM
Start with the simple check all the fuses and fuel pump relay battery connections
Eagle is offline
post #3 of 11 (permalink) Old 10-05-2014, 06:40 PM Thread Starter
RaiderV-VZ's Avatar
I checked all the fuses in the fuse box and the battery cables. I'll double check everything again once I get the battery charged again, since I ended up draining it trying to start it back up. Thanks
post #4 of 11 (permalink) Old 10-05-2014, 10:13 PM
Sounds like the fuel pump shut off. I'd pull the air cleaner and squirt a little fuel behind the throttle plate and see if it will hit off that. If it will, ignition is most likely fine. First thing that comes to mind would be the connector to the fuel pump under the tank console. Had any parts off lately?
DuraGlide is offline
post #5 of 11 (permalink) Old 10-05-2014, 11:02 PM Thread Starter
RaiderV-VZ's Avatar
I checked that connector and it appeared to be connected properly. I haven't seen or heard anything come off. I tried cranking it over again with a charged battery and it is not getting any fuel at all. Thanks for the recommendations.
post #6 of 11 (permalink) Old 10-06-2014, 05:49 AM
When you turn the ignition switch to on and the run button to run do you hear the fuel pump prime before you hit the start button?
post #7 of 11 (permalink) Old 10-06-2014, 09:12 AM
fltru103's Avatar
It's 2013, it still must be under warranty.
Call and have them pick it up. If it doesn't run they will cover the tow and find the problem.
in my garage now...
2007 Dyna Screamin Eagle ... SOLD !
2011 RGU Merlot SunGlo
fltru103 is offline
post #8 of 11 (permalink) Old 10-06-2014, 03:34 PM Thread Starter
RaiderV-VZ's Avatar
rlaf75- No, I did not hear the fuel pump prime nor did the engine light come on. This morning I checked again to see if it would start and it started right up...fuel pump prime on and engine light on. I tried it several times and it started right up. I decided to take it off the trailer and put it back in the garage and wouldn't you know it, it did not start. No fuel pump prime and no engine light again. I'm gonna have to take it in or have it picked up. It is under warranty still, but was hoping it was something simple and wouldn't have to take it in to the dealership and have it sit there for days.
post #9 of 11 (permalink) Old 10-06-2014, 03:35 PM Thread Starter
RaiderV-VZ's Avatar
I was hoping I didn't have to.
post #10 of 11 (permalink) Old 10-06-2014, 06:09 PM
Check the ecm plug under the seat ?
Big_gary is online now
Rear cylinder shut down Citykid *General Road Glide Discussions/Pictures 11 09-09-2012 09:30 PM
Does the ECM shut down the bike when too hot? jcanrun *General Road Glide Discussions/Pictures 3 07-13-2011 11:11 PM
2007 Cylinder shut down Devilhog *General Road Glide Discussions/Pictures 13 07-02-2011 09:26 AM
Electronic shut down on trip skipperfltr *General Road Glide Discussions/Pictures 16 06-16-2011 01:50 AM
2010 cylinder shut down BillyBob *General Road Glide Discussions/Pictures 45 07-07-2010 10:37 AM
