Ignition switch SOS - Road Glide Forums
post #1 of 10 (permalink) Old 10-05-2014, 08:51 PM Thread Starter
Unhappy Ignition switch SOS
Just picked up a 2015 Road Glide special, first touring bike. Today I was doing a little cleaning after a nice ride and decided to roll the bars forward a bit. I removed the ignition switch with no issue per the videos on the net and adjusted the bars. I put everything back together without issue (so I thought). I must have misaligned some of the internal lock tumblers or put the switch down too far.
1. Ignition turned to lock and bars are not locking
2. pressing the detent on the bottom of the switch no longer allows it to slide out of the barrel.
3. Looking at a friends new glide I see that his switch assembly doesn't sit down as low as mine
If I have the switch in the lock position I have to push in the detent on the bottom to get the assembly to rotate to the other positions otherwise its like its locked.
How do I reverse my screw up without taking it to the dealer?
mray81 is offline
post #2 of 10 (permalink) Old 10-05-2014, 09:37 PM
Sounds like the tab on the bottom that is supposed to be in the fork lock notch is below it. The wedge that comes out for the detent is not in the right groove. Have to push the detent and rotate the switch until the ignition notch (upper tab) and the fork lock notch (lower tab) align again. Had the same issue last time I had the switch out of mine and took a little patience to get it back out and then back in right.
DuraGlide is offline
post #3 of 10 (permalink) Old 10-06-2014, 09:36 AM Thread Starter
that was my thought as well. tried rotating it around and lifting it for a while last night with no luck. Had to walk away. I'll try again tonight.
mray81 is offline
post #4 of 10 (permalink) Old 10-06-2014, 05:53 PM Thread Starter
Ok looking at it now the detent is in the lock groove when ignition is turned to lock position but the whole knob is too low to let the detent slide around in the groove. Maybe tumblers are out of sync holding the assembly down too low????
Anyone have any suggestions?
mray81 is offline
post #5 of 10 (permalink) Old 10-06-2014, 06:30 PM
Yea, just keep messing with it. You will get it. It always takes me a few times too. Its all about alignment.
post #6 of 10 (permalink) Old 10-06-2014, 08:06 PM Thread Starter
Finally got it. Thanks for the input!
mray81 is offline
post #7 of 10 (permalink) Old 10-06-2014, 08:09 PM
Triplej's Avatar
How many beers did it take A couple more and a few deep breaths usually does the trick for me
Triplej is offline
post #8 of 10 (permalink) Old 10-06-2014, 08:11 PM
RoadGlideGary's Avatar
++ on the advice. You can't mess it up. I practiced with mine after watching the video and never had a problem. Then I took the ignition switch and upper retainer off when I did my suspension upgrade. Exact same issue you have. Try and walk away. Try inserting with knob in off position (not locked position) pushing tab up ( key in) but not turning key to full left until you have knob full left and depressed, then turn key full left. There are only a few options. It is not F'd up - just a sequence / initial insert issue. I'd try on mine again to confirm but I'd F it up!
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #9 of 10 (permalink) Old 10-06-2014, 08:29 PM
What really sucks is when you get it right the first two times you tear it out thinking you are the Jedi Master better than everyone else and then the third time you jack it up ..... after a few beers still jacked up ..... 24 hours later get it right. It's like a right of passage, you WILL jack it up
jethro_3 is offline
post #10 of 10 (permalink) Old 10-07-2014, 05:47 AM Thread Starter
Yep, tried it a few times before this with no issue. Even did it on a friends bike while mine was jacked up just to make sure I wasnt missing something. Totally frustrating but happy its fixed.
mray81 is offline
Removing your ignition switch joke Do-IT-Yourself 21 01-05-2019 03:18 PM
Help removing ignition switch. Switch seems stuck? Driftah Controls & Handlebars 5 11-04-2015 08:18 AM
ignition switch Graybone32 *General Road Glide Discussions/Pictures 10 06-27-2011 02:04 PM
2011 RGU Handlebar swap / ignition switch question craigp95 Controls & Handlebars 6 06-22-2011 06:03 PM
Chrome Ignition Switch Cover for Road/Glide cestaro Aftermarket Accessories 4 06-06-2011 06:17 AM
