bad VR or bad stator? - Road Glide Forums
post #1 of 15 (permalink) Old 10-12-2014, 11:57 PM Thread Starter
Gonekat's Avatar
went out the other day and while cruising through town, the radio turned off and when i looked down, i noticed voltage was at 16+. completly pegged. I pulled over and radio came back on, voltage normal. I continued on and then battery light and check engine light came on. Voltage at 11ish. Any ideas which part of my charging system is causing this. My suspisions are VR, but not positive. Bike is an '11 FLTRX w/ 26k.
GK
2011 RGC, Sedona Orange 103" w/ 48H cams,PM Icon 21" wheel,Kury Mach 2 intake,Jackpot 3.5, PM brake and shift levers, CB 14" TRSSC shield, Sinister 14" apes, custom levers.Black exhaust,floorboards,pegs and crash bar.
Gonekat is offline
post #2 of 15 (permalink) Old 10-13-2014, 09:58 AM
Paul's Road Glide's Avatar
I recently had to replace my VR and these were my symptoms.
Voltage meter would drop to about 11 and battery & check engine light would come on. After about 10-15 the volt meter would then go back up to normal readings. it did this about 3 times.
I'm betting its the VR. I have had to replace two of them already.
But a couple of things to keep in mind is make sure you check your battery too especially if your charging system spiked up that high. (edit, this is to make sure it didn't get over charged at some point)
You Stator should generate about 26-27 volts when the bike is running and your VR is supposed to correct that so the sudden spike and dropping of volts indicates your VR might be shot.
Paul's Road Glide is offline
post #3 of 15 (permalink) Old 10-13-2014, 10:08 AM
If your voltage is too high it is probably the regulator as it regulates the amount of voltage that gets through thus too much voltage the regulator is not doing it's job.
Drew
HogPro is offline
post #4 of 15 (permalink) Old 10-13-2014, 10:19 AM
JayKS's Avatar
I agree, probably the VR, but I'd cover all the bases here.
- Take your battery out (check your connections while you're in there, of course), take it to an auto parts store and have it load tested.
- Check the voltage being produced by your stator/rotor. Should be somewhere around 18-22VAC per 1000rpm if I recall.
- Do some static checks on your VR. Just google 'how to check harley charging system' and you'll find a procedure.
JayKS is offline
post #5 of 15 (permalink) Old 10-13-2014, 09:32 PM
tsmartt's Avatar
Same thing on my 13 RGC. Got the regulator and stator replaced under warranty. Last week my buddy had the same thing on his 13 RGC. Regulator only. MOCO needs to get off the Chinese crap electronics!
Quattro / 16 RGS / Dragula2 2:1 / Drago 565 / ThunderMax Tuner / Fuel Moto Breather / Klock Werks Flare / Custom Dynamics LEDs
Orange Crush / 13 RGC / Dragula 2:1 / TMan 555TQ / ThunderMax Tuner / Zipper's Max-flow Breather / Klock Werks Flare / Custom Dynamics LEDs
tsmartt is offline
post #6 of 15 (permalink) Old 10-15-2014, 08:29 AM
BH#103's Avatar
Had the same issue with my '12 two weeks ago. Battery and check engine lights came on. In the morning I had a low voltage issue and later that same day I had an overcharge. Both conditions produced erratic behavior from the bike accessories. DTC codes all read high and low voltage problems. (Don't remember off the top of my head, but have them written down if you need them) Having high and low issues is a lack of being regulated. Pulled my regulator off and could smell that it was smoked. Mentioned the problem to my local dealer and they firmly said they agreed. So I purchased the new regulator with a hefty price tag and reinstalled. The bike was fixed and the gauge was rock solid. Also if it is a '12, it may be under warranty possibly. They had a recall for this in early '12 that only a certain run of production #'s fell into. Good luck!
"SLIVER"
BH#103 is online now
post #7 of 15 (permalink) Old 10-15-2014, 10:08 AM
The other thing to check is open your derby cover and if it smells burnt the stator is toast. You can test at the plugs with a meter but I had a similar issue (only with low voltage) and both the stator and regulator were replaced under warranty.
Drew
HogPro is offline
post #8 of 15 (permalink) Old 10-15-2014, 03:39 PM
Biggy's Avatar
It makes sense that the VR might be the problem, it limits current from the stator/rotor, so if it was high at 16 then low at 11 means it should be the VR. While you have it apart check the stator/rotor, my 07 requires 16 to 20 at 1,000 rpm, this reading should double every 1,000 rpms. Also make sure your battery returns to a full charge, HD has a high standard for their batteries, I think 12.85 is a full charge.
Sincerely, Tim
2007 FLTR
Biggy is offline
post #9 of 15 (permalink) Old 10-15-2014, 04:53 PM
MShell's Avatar
GK
Everything you described is exact symptoms I had. Was the VR. Hope that helps
Lug nut rule, the one with the most lug nuts wins
MShell is offline
post #10 of 15 (permalink) Old 10-15-2014, 05:52 PM
redbaron's Avatar
Same symptoms as on mine also. Was the VR , I am on my 3rd regulator since 2012 !!
2012 Vivid Black, FM Ceramic 2-1-2 Header + 4" slash up mufflers Power Vision, PM Super Gas MERC A/C, 12" Windvest, CVO Solo Seat, XT Rokker & Hawgwire cs300 Amp, 10" Outlawz, CD Led's, Arlen Ness lowers, Ohlins S36E + progressive monotubes
redbaron is offline
Bad stator and comp Wickedgmc Engine Related 5 10-04-2015 01:39 PM
if you had a VR failure please post. jupiter Troubleshooting for Road Glides 39 09-02-2012 02:06 PM
stator/regulator dddboat Troubleshooting for Road Glides 8 04-03-2012 07:30 PM
How long does it take to change a stator? ironmark *General Road Glide Discussions/Pictures 10 01-31-2012 10:27 PM
Oil Leak from Stator Wiring? jcanrun *General Road Glide Discussions/Pictures 8 01-06-2011 03:15 PM
