Need help stabilizing my RG - Road Glide Forums
post #1 of 10 (permalink) Old 11-02-2014, 02:02 PM Thread Starter
Othello7213's Avatar
Hello all,
i'm trying to narrow down what could be causing my wobble at around 90 MPH. I have a 23" front wheel with a HHI bolt on rake kit, mono tube front shocks and progressive 944 shocks in the rear set a 2 (if memory serves me correct). I also have a progressive and alloy art rear stabilizer (both installed). I figured my set up was good after all that. Went out last night and she was all over the road. Few things I was wondering:
1 could my suspension be to soft
2 Does my razor tour pack cause the ass end to sway
3 air pressure in the tires ( i have a needle gauge on my pump and I just let it go till it hits the green lands somewhere near 36) how much air is good normally?
4 Does having Apes increase the wobble
5 do stretched bags play apart by catching air
6 ride height (is lower better or vice versa)
7 Is there a way to flat out fix the wobble or is it something i'm going to have to live with
thanks in advance for your help
"LETS RIDE"
Othello7213 is offline
post #2 of 10 (permalink) Old 11-02-2014, 06:29 PM
Does it do it at 80 ? Might be as simple as a tire balance issue.
post #3 of 10 (permalink) Old 11-02-2014, 06:40 PM Thread Starter
it's done it at low speeds if I sweep across 2 lanes merging on to the belt way but mostly at high speeds
"LETS RIDE"
post #4 of 10 (permalink) Old 11-02-2014, 06:43 PM
Tire pressure tire pressure tire pressure. Run at the listed max PIS on the side of the tire. I assume Avon front? What is on the rear?
HogPro is offline
post #5 of 10 (permalink) Old 11-02-2014, 06:45 PM Thread Starter
you are correct good sir and the rear is the same.
"LETS RIDE"
post #6 of 10 (permalink) Old 11-02-2014, 06:48 PM
I'd be questioning the bolt on rake kit then. It may take some process of elimination to figure out this problem with all your mods.
Hows your fallaway ?
post #7 of 10 (permalink) Old 11-02-2014, 07:00 PM Thread Starter
are you talking about when I let off the throttle?
"LETS RIDE"
post #8 of 10 (permalink) Old 11-02-2014, 07:36 PM
Neck bearing tightness.
post #9 of 10 (permalink) Old 11-02-2014, 10:07 PM
Biggy's Avatar
I think Big Gary is on to something, the neck bearing is critical to the ride on HD bikes, I've seen many problems (accidents) from improper adjustment to these bearings. Check the manual for details but all that might go out the window with your rake kit, so make sure to contact the manufacturer with this problem.
Sincerely, Tim
2007 FLTR
Biggy is offline
post #10 of 10 (permalink) Old 11-30-2014, 02:07 PM
taoist's Avatar
Neck Bearings
If the neck bearings are too loose, the apes will cause the wobble also.
2006 Black 95 cu in Dyna Street Bob
2017 Black Road Glide Special
taoist is offline
Need help - need a tuner with some skills in SW Mich Captain America Dyno Results 1 06-03-2017 12:51 AM
need help figuring which bars I need ironmike666 Controls & Handlebars 14 01-06-2013 11:56 PM
Lowering my 12 RG, need help please ! TNFatty Suspensions 2 12-17-2012 07:58 AM
01 RG SE Engine Light On-Need Help scteach Troubleshooting for Road Glides 15 05-03-2012 04:48 PM
I Need help purchasing shocks. 2010 RG. gabbyduffy Suspensions 10 01-01-2011 09:00 AM
