Check Engine Light - Road Glide Forums
post #1 of 6 (permalink) Old 11-09-2014, 11:44 AM Thread Starter
RGLove12's Avatar
Check Engine Light
I changed my handle bars last week and apparently something is not right, my engine light came on and the orange cruise light is blinking whether the cruise switch is on or off. I did use the cruise and it did not turn green like it used to it worked for about a minute light stayed orange and then it went off cruise.
Any suggestions? is it a pinched wire. I did run internal wiring through the handlebars.
Help Help Please
Dave Mackie 575 Cams, Master Tune TTS, V&H High output, Agitators, Blacked out, C&C Seat, CVO Guages
RGLove12 is offline
post #2 of 6 (permalink) Old 11-09-2014, 04:28 PM
mmfinn's Avatar
Has to do with the TBW. Got the same thing on mine and the dealer fixed under warranty. What codes are you getting?
mmfinn is offline
post #3 of 6 (permalink) Old 11-09-2014, 06:20 PM
FDR's RGC's Avatar
Had same problem when I changed my bars, took apart and started over while carefully running wires thru bars. Must have done something right cause light went off.
FDR's RGC is offline
post #4 of 6 (permalink) Old 11-09-2014, 06:34 PM Thread Starter
RGLove12's Avatar
was hoping no to do that but if that is what is required will have to take the darn thing apart and re-do. So nothing to do with any fuses etc. Any suggestions.
Will try again.
RGLove12 is offline
post #5 of 6 (permalink) Old 11-09-2014, 07:15 PM
Will try again.
Check for codes.
post #6 of 6 (permalink) Old 11-22-2014, 11:54 AM Thread Starter
RGLove12's Avatar
Issue Resolved
TBW connector was faulty.. Thanks for all your help..
This is why I love SSS (Secret Shark Society)
RGLove12 is offline
Check Engine Light and Battery Light following Jackpot 2-1-2 install PearlBlueUltra Troubleshooting for Road Glides 9 06-15-2014 04:59 PM
Check Engine Light Ran8175 Troubleshooting for Road Glides 0 07-17-2011 02:17 PM
05 Roadglide check engine light camperfan Troubleshooting for Road Glides 8 05-03-2011 08:36 AM
Engine check light keeps coming on 2011 RGC madmatt Road Glide Specific Discussions 11 02-14-2011 12:14 AM
Oil Overfill and Check Engine light Biker Tom Troubleshooting for Road Glides 5 09-15-2010 08:01 AM
