no fuel pump!!!! - Road Glide Forums
post #1 of 16 (permalink) Old 11-15-2014, 11:04 PM Thread Starter
no fuel pump!!!!
ok here is my issue I pick up the bike Thursday night ride it 20 miles home go out Friday after work to move it hit the button fuel pump primes hit start it sputterd recycled ignition no fuel pump that's all she wrote hasn't run since .
so I hook up tender check fuses pull line off tank hit the tank with ignition on just cranks I did check power at tank harness on there is power at plug on white wire not the red wire...any sugestions I have a tmaxx that was just tuned so im not sure if I should swap my stock ecm to see if it will start
milkman48 is offline
post #2 of 16 (permalink) Old 11-16-2014, 12:31 AM
I don't know the colors off hand but you should have power to a wire with the key on when the pump is supposed to be priming then it should turn of after about 5 sec. It should have constant power while cranking and running. If you have power but no pump then you have a bad pump. What year is the bike
post #3 of 16 (permalink) Old 11-16-2014, 01:05 AM Thread Starter
08 I will check other wire for flash tomorrow
post #4 of 16 (permalink) Old 11-16-2014, 12:22 PM Thread Starter
Well I have power at yellow/white wire. And no spark.
post #5 of 16 (permalink) Old 11-16-2014, 12:40 PM
If you don't have spark at the spark plug side, check at the coil side too to make sure the plug wires are good. Then I'd check to see if you have power at the coil harness. Now its the process of elimination, coil, regulator and crank sensor. For shiznits and giggles swap the ECM back in and make sure it's not the tuner. Also check the relays. I had a buddy that didn't ride his bike for several weeks because he that there was something majorly expensive wrong with his bike and he didn't have the money to get it fixed. Come to find out a simple $6 relay was giving false readings when testing
post #6 of 16 (permalink) Old 11-16-2014, 12:58 PM
I just texted my buddy about it and he said he was getting no spark and no injector pulse. He said he found the "system relay" was giving the false readings when he tested it. He told me that he went to an auto parts store and replaced it for under $10. EDIT he just said he got it from a local HD dealer for under $10. Go figure
post #7 of 16 (permalink) Old 11-16-2014, 03:40 PM Thread Starter
Well I tossed it on my lift started pulling fuses didn't find any blown but apparently I found a fuse not making contact. All good bike running again.
post #8 of 16 (permalink) Old 11-16-2014, 05:32 PM
It's always the way it is, something so simple gets overlooked. Glad you got it going again
post #9 of 16 (permalink) Old 11-17-2014, 10:41 AM
I had a fuse contact issue on my 08 that affected my brake lights. It seems that the contact tabs in the fuse box can fatigue over time and lose contact with the fuse prongs.
It was a simple fix I just had to bend the contact in the fuse box a little and the connection was restored. The hard part was finding the problem because it is easy to overlook this condition.
post #10 of 16 (permalink) Old 11-19-2014, 07:59 AM Thread Starter
I picked up some electrical cleaner goi g to clean up fuses make sure hes ready to ride
Fuel Moto 107" hi output R&D motor 151Hp Pump Fuel fuelmoto Dyno Results 5 01-22-2014 08:24 PM
Fuel pump primes NO START!!! camile82 Controls & Handlebars 5 07-18-2013 10:46 PM
ACR's or Fuel pump,...need answers. Smash.usmvmc Fuel Moto 2 10-24-2012 12:37 AM
Gas tank and fuel pump question jim_b Troubleshooting for Road Glides 3 05-20-2012 12:04 PM
Fuel pump wanted Speedychp61 Classifieds Archive (3 months old+) 0 11-21-2010 10:02 PM
