Wheel bearings - Road Glide Forums
post #1 of 3 (permalink) Old 05-16-2012, 01:22 PM Thread Starter
Wheel bearings
I am starting to think that the wheel bearings in the new front rim I have aren't fully seated. It started with the wily shiny spacers that cover the rotor mounting hardware. One side sits perfectly flush while the other leaves a small gap. (left side of the wheel has the gap) when I installed the yaxle I noticed the metal sleeve between the bearings was a little off center and had to realign it. (shouldn't move around if bearings are tight right? Once the yaxle was installed (flush mount) left side fits flush, the right has a minor space between the lower fork and the end of the axle. (looks to be the same size as the gap between the spacer and rotor hardware. Now I'm hearing a squeal the last foot or two when I brake coming from the front brakes. I have a feeling this is all connected. Any ideas how I can try to press the left bearing in more? Looks to be about 1/8 out since this is the distance between the spacer and rotor as well as yaxle and fork lower.
SGT_Rob
The very essence of leadership is its purpose. And the purpose of leadership is to accomplish a task. That is what leadership does–and what it does is more important than what it is or how it works.
~Colonel Dandridge M. Malone
SGT_Rob is offline
post #2 of 3 (permalink) Old 05-16-2012, 02:04 PM
staush's Avatar
3/8 " all thread the length of your axel, 2-3/8 bolts and flat washers a little smaller than the outside dia. of the bearings. Slip thru the hole and tighten. If it doesn't move than maybe you have the wrong size bearings?
staush is offline
post #3 of 3 (permalink) Old 05-18-2012, 04:24 PM
Pull the wheel off and use a socket that matches the diameter of the outer race and a hammer to try to push the bearing in farther. You can heat the hub with a torch first to get the bearing to move easier. When the tone changes you have seated the bearing. The spacer between the two bearings will sometimes move around a bit, this is no worry as it just supports the inner races when the front end is together and the axle is torqued...
Dfwhockey17 is offline
Wheel Bearings, UPSGUY Wheels and Tires 8 05-17-2015 07:20 AM
cheep azz wheel bearings JacktheBagger Wheels and Tires 24 07-14-2014 09:27 PM
Wheel Bearings JacktheBagger Wheels and Tires 26 06-21-2013 06:51 PM
18" agitator wheel w tire and abs bearings Sinnister Sold 7 01-28-2013 07:24 PM
How to tell if wheel has ABS bearings? fltrx103 Wheels and Tires 4 05-16-2012 03:25 PM
